EMINENCE LAB 12 V2 |
DRUMSZ
Registered User Joined: 01 October 2009 Location: USA Status: Offline Points: 17 |
Posted: 08 October 2009 at 1:32am |
First off hi all been lurking around here for a while
question i have 2 emin. lab 12 v2 hanging around want to supplement the pa at the club i work they have eaw tops 2 15 1 6 mid and 2 tweets low end is 2 jbl jrx 18's used to have 4 but the guy at there other club blew out there 18's... and my loss any way i wana build a couple punishers with the eminence saw the lab's nice but i dont wana buy 2 more labs. any suggestions ? thanks all and love the build picks !!!!!!! |
sKs01
Old Croc Joined: 11 April 2008 Location: sheffield Status: Offline Points: 1744 |
1 or 2 horn loaded cabs wont work, minimum of 4 per stack is usually recommended...
unless they are of the tapped variety, which the lab 12 could be quite suited to, use the search term tapped horn in the forum search and theirs at least one or two designs for 12" drivers around. their design wont be optimised for the lab 12, try downloading hornresp and designing one for yourself if you feel up to the challenge, or attempt to adapt an existing design for that driver. hope that helps.
darkmatter
lab 12 wont work in a punisher, tapped horn sounds like a good possibility.
are you planning to run two different types of bass cabinet (12" horns and 18" reflex) on the same frequency range?
DRUMSZ
Thanks for the responses
I'm looking for a tapped like suggested something like like the Danley nice size and they will be stuffed in each corner Yea it would be nice to use the same freq. only cause the cords are already there from the other 18's but i know it probably wont work so if i have to I'll break down my rack and use some of my stuff. By the way is there a plan similer to the Danley or do i just build a lab sub and drop it in the middle of the stage under the front monitor ? Thanks again. |
darkmatter
I don't think you'd have good results running both alongside each other, you'd be better off spending your time/money on more JBL 18s in my opinion.
The are some interesting tapped horn designs in the 'other plans' section of this site or over on diyaudio.com.
If you're looking for cheap options capable of plenty of bass output I'd recommend you check out JBell's thread on DIYaudio about a front loaded horn for cheap MCM drivers.
As sKs said there's probably no point building a single lab sub. The horn mouth wouldn't be large enough to make full use of the horn length and low frequency output/excursion control would suffer.
DRUMSZ
Thanks guys sad to hear but ive done dumber things in my life lol
so i did some scouring on the we and found this site http://www.geocities.com/loudspeakerguru/subindex_page4.html single 12 for a lab12 ?? any ideas on it???? may do one just to see till i can do a real punisher agin thankz time to go get deaf at the club |
Stories
New Member Joined: 05 August 2008 Location: London Status: Offline Points: 8 |
Sell the Lab12's and buy a pair of the punisher drivers or build a Lab (cut enough wood for a least a second tho : o ).
I've found one Lab a side (2 total) works quite well in a fairly small (~8m x 18m) rooms i've used them in, banging for DJ's and rock'in for bands! Certainly not as bad as people seem to surggest, there just BIG, which is only an issue if you need to move them around lots. Personally prefer the Lab's to the punnishers I've heard, though the punishers do work a lot higher and give that low mid chest thumping tingle, where as the Lab's do Sub and thump and wobble you (need somthing above them for the low mid stuff) lots. Matt |
DRUMSZ
tell ya Im bumming but i do love the look over the labs !!
built a couple hd15 already and the moving isn't a prob scence i practically am the tech for both clubs ill just put what ever sounds better in one and do sound there i do want that just thumping sound not just bass i did do sound in one of the areas biggest clubs and they did have nothing but scoops and the like for bottom end rrrrrrrrrrrrrrrrrrrrrrrrrrrr bass and drums love it thankz |
