Eminence |
Konstantinov ![]() New Member ![]() Joined: 24 July 2022 Status: Offline Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 24 July 2022 at 4:00pm |
Hello just to mention that this is my first post here. im having 3 speakers - Eminence Omega Pro-15 Eminence kappa Pro-15 Eminence delta 15a what enclosure will you recommend for them scope? vented? . I want to use them as a stage subwoofers.
take a month off and no answers? does this mean that these speakers can only be used in the PDF circuit? |
DMorison ![]() Old Croc ![]() Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1617 |
Unfortunately none of them are really subwoofer drivers. Also, due to their different parameters, you wouldn't be guaranteed to get them all sounding the same if you tried to use them together.
Probably best to sell them and buy matching drivers that meet your needs.
Edited by DMorison - 09 August 2022 at 7:26am |
monkeypuzzle ![]() Young Croc ![]() Joined: 25 January 2005 Status: Online Points: 897 |
Are your making speakers for electronic dance music or live bands? Having three different speakers is not best but it does give you a chance to try things out and learn about how speakers work. If you have the time and some wood, make a THAM 15 and a Cubo. Try each speaker in them and decide which you like best. Look at the Theile Small (TS) parameters for each one and this will help you understand what changes what. Then sell the other speakers and look for more of the best one.
thanks a lot for the eadvice. Ill use them for live band. I was thinking to use them not for subs. Maybe only omega can be used as a sub. The info from eminence's site is that its "High power driver for pro audio as a woofer in vented enclosures. Also suitable for horn loading and scoops." I was wondering what horn or scoop can be done with it. the rest of the speakers i want to use them as midrange speakers ... tops maybe.
DennisTheMeerkat ![]() New Member ![]() ![]() Joined: 04 November 2017 Location: Sweden Status: Offline Points: 3 |
Can always build 186/1850 bins for them
