  New Posts New Posts RSS Feed - eq/crossover suggestions
Milo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Milo Quote  Post ReplyReply Direct Link To This Post Topic: eq/crossover suggestions
    Posted: 16 November 2007 at 12:41am
ey up.
Anybody have tips for EQ and crossover settings when playing mostly dub and drum & bass music?
We have 2 x 18" 650w eminence and 1 x 15" 800w eminence,  2 x 12" 250w eminence and 3 x motorola tweeters.
Are there any 'rules of thumb' when it comes to setting the best crossover points?
Ta
type in milodub after myspace.com
Lexioman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lexioman Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2007 at 5:55pm
Hi Milo,
my humble opinion it's that when you want to play dub music in a proper way, a custom made preamp can do the work more than any other gear. It works as crossover, with crossovering points made just for that kind of vibes and boxes, you got a lot of equalization possibilities, knobs etc, and (last but not least) you can enjoy with some "kill" switches...
Think about it Tongue
PS Why not consider increasing the tweeter section? Piezo are cheap and they blow so easily...buy some more of that!
Edited by Lexioman - 16 November 2007 at 5:56pm
www.myspace.com/sankararecordingstudio
www.myspace.com/lexioman
Milo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Milo Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2007 at 2:36pm
cheers for that man. Any particular pre-amps u had in mind in your suggestion? id like to check sum out...
Yeh definately agree on the tweeters mate.
Jhodas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2007 at 5:49pm
check out JTS preamps. (http://www.jtsstudio.co.uk/pages/preamps.htm)
mskeete, one of our own members is also a respected builder.
(http://mostec.co.uk/electronics/preamps.htm)
Crossover points on these are fixed, but can be changed at the time of build.
I'd hire a LMS first to obtain your crossover points.
HTH.
Jho
Edited by Jhodas - 18 November 2007 at 5:50pm
