  New Posts New Posts RSS Feed - es18bph - SD18
es18bph - SD18
 Post Reply Post Reply Page  123 6>
H.. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H.. Quote  Post ReplyReply Direct Link To This Post Topic: es18bph - SD18
    Posted: 11 January 2008 at 2:48am
Has anyone put the SD18 into these boxes?
It looks like it won't fit with the braces.
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2008 at 7:04pm
the plans state that the SD18 can be used though it does look very close. i'm building some ES18-BPH at the moment so when they are finished i will put up some pics & measure the driver clearance.
Edited by Static Age - 16 January 2008 at 7:06pm
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 16 January 2008 at 7:39pm
SD-18 will fit
however
SD-18EL will not
Ex Nexus_3
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2008 at 5:09am
my version . change outpart brace...
Edited by TDA-Audio - 21 January 2008 at 3:30pm
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2008 at 2:54pm
gorgeus, I built four of these about a year and a half ago,,,,,,, unfortunately i dont have any pics, also they wernt as nice as tdas box shown above, nice simple effective box though!!!
If you want people to feel the bass then a reflex design is probably best as you get the most air movement per decibel from those.      errrrr yes wtf?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2008 at 11:05am
Mark, did you put handles on the ES18's that you built?
mine are currently in a a similar state to the pic posted above & i'm debating possible handle positions, to be honest i cant find a good place to put them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2008 at 3:31pm
nope the only "accesory" was the small hole in the back for speakon socket, they were a mdf practise to see how good our saws were...........
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2008 at 12:32pm
Any other drivers ideal/recommended to be used in this type of cab ?
double fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote double fred Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2008 at 1:33am
Hiya,
thought I'd register to show you that :
es-218bph
so yeah es-218bph with usb style bracing, c18-650el loaded.
we're making 2 for testing, each cab will be fed 1500w of clean Lab Gruppen power.
if it sounds good we'll make 2 more, hoping that a stack of 4 will go quite low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2008 at 1:36am
heeeelo!!!!! thats nice
how are you finding the challengers???
Post Options Post Options   Thanks (0) Thanks(0)   Quote double fred Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2008 at 1:45am
Haven't had a chance to try them yet. The cabs aren't finnished because it's blody cold right now.
I've heard those drivers in a very small reflex enclosure before and I was very impressed. I'm no good at describing a sound in details but I can definately say it sounded really good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2008 at 2:43am
I am probably going to be buying a few of these soon, hence the interest in them,
Just worried whether they will survive long term hard useage in a horn.....[a damn long horn at that]
