es18-bph |
rish
Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
Topic: es18-bphPosted: 02 September 2008 at 3:22pm |
I am building the es18-bph and would like to know what is the frequency range of this box.Do I still need to put a sub under the es18-bph and whats the best mid high cabinets to go with this box? |
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 02 September 2008 at 3:56pm |
general consensus is that this box plays best 50<180 hz but is playable from 40<200 depending on stack size etc. it was designed to play 70hz and up on some lab horns I believe but a stack of four I can imagine would be great for say 40hz<180hz. any good horn loaded mid top that can drop to 180 hz preferably 160 or lower will probably be a good start, what do you play thorugh your system? |
insert silly sentence here
smithers
Posted: 02 September 2008 at 4:32pm |
es18's were around before USB'S which davey T designed to sit on top of his lab subs
basically the same box, just slightly modded to fit over a pair of labs. we use our from 70-180hz with MT121's on top and hogs underneath...i dont really like crossing them any lower or higher as i think thats where its gets a bit iffy....you could use them as stand alone bass bins in groups of 4, but youd still only be hitting 45hz or so. personally i think its a pretty hard to beat DIY combination....but i would say that after spending months building it. |
Mark James
Posted: 02 September 2008 at 5:04pm |
ahhhhr for some reason i thought we were talking about usb's I built some es18 as well shows how much my brain is somewhere else] seemed good from 50hz<180hz ish to me, playing tekno they were quite a kick bin. Depends what you are playing. larger stacks will reach 40hz |
