eucalyptus ply |
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Topic: eucalyptus plyPosted: 01 September 2022 at 11:33am |
just bought a few sheets of birch this morning (
).. and the place reckoned they're running out and they don't know where the next batch will come from.. so they recommended eucalyptus ply as an alternative.they showed me some 12mm as an example... the face looked ok, didn't look to have voids in it, the plys may have been a bit thicker than in birch. anyone used it or looked at alternatives if there is a proper drought coming? |
APW
Joined: 13 November 2012 Location: UK Status: Offline Points: 1234 |
Posted: 01 September 2022 at 5:43pm |
I have used 13 lamination 18mm eucalyptus ply about 10 years
ago and it “can” be Ok, but still not as good as decent birch. The lot I got cheap was fairly decent with very few voids (only found one in the 10 sheets), however a mate of mine had a batch that had a quite few voids. Its not as nice to work with as birch, however I’ve worked with a lot worse!! Edited by APW - 01 September 2022 at 5:46pm |
woody2
Posted: 01 September 2022 at 8:12pm |
Mainly comes from china......
Meat Substitute
Posted: 01 September 2022 at 8:31pm |
I thought that poplar was meant to be the best stand-in in the UK. Correct me if I'm wrong. If it wasn't so bloody expensive I'd like to try a build using Tricoya (could build it, fit a weatherised speaker and leave it in the woods :) ).
snowflake
Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3443 |
Posted: 02 September 2022 at 8:52am |
poplar is fine for internals - in fact better IMO with a higher stiffness:weight ratio. It does dent though - but there is birch face poplar core ply available for external panels. |
