EV DX38/Dynacord DSP244 help |
tidyjim
Joined: 04 November 2023 Location: United Kingdom Status: Offline Points: 21 |
Topic: EV DX38/Dynacord DSP244 helpPosted: 04 November 2023 at 4:32pm |
Hello all, hope you can help.. I have a EV DX38 digital speaker processor that’s locked with a 4-digit security code that I don’t have, tried the default but no go.. can anyone help me to get the unit functioning again? Unfortunately it’s retrofitted with NRS 90246 contact closure interface so has no RS-232 serial connectivity to be able to clear the EEPROM via terminal! Kind regards, Jimmy
FOO
Joined: 23 December 2018 Location: Denmark Status: Online Points: 954 |
Posted: 04 November 2023 at 5:42pm |
Press and hold down the Edit key and the Right Arrow while powering it on. It will get you into service mode where you can set it to re-initialize the memory which should reset everything.
tidyjim
Posted: 04 November 2023 at 6:43pm |
Thanks for your speedy reply! Yeah have tried this several times to no avail.. if it helps it’s running firmware/software revision v3.21
Thank you
KDW32
Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 770 |
Posted: 04 November 2023 at 6:59pm |
Have you tried EV support for a suggestion?
tidyjim
Thanks(1)
Posted: 04 November 2023 at 7:55pm |
Sure have, will let you know what they come back to me with 👍
Think the answer may be to find somebody somewhere that has a RS232 interface they pulled when swapping out for the RS485 interface!
PauliePaul
Joined: 14 August 2009 Location: Birmingham Status: Offline Points: 1485 |
Posted: 27 November 2023 at 5:04pm |
Just sent you a message.
tidyjim
Thanks(1)
Posted: 28 November 2023 at 10:25am |
Am a little confused as to how I access PM’s?
DMorison
Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1740 |
Thanks(1)
Posted: 28 November 2023 at 8:20pm |
You need to have more than 10 points (ie 10 posts, more or less), unless someone nice decides to use the "thanks" function to boost your points....
Edited by DMorison - 28 November 2023 at 8:21pm |
