EV P-1200 problem :( |
Page 12> |
serioussound ![]() Registered User ![]() Joined: 01 December 2013 Status: Offline Points: 443 |
![]() ![]() ![]() ![]() ![]() Posted: 25 December 2015 at 4:19pm |
Hi guys. I want to give this problem a shot here even if its little embarassing.
I have: 1 pcs working Dynacord L300 1pcs EV P1200 (faulty) The EV p1200 amp was faulty channel b was glapping when turn on and off the amp. So I decided to change the PCB board from the working Dynacord L300 to the "glapping" EV P1200. The model of the PCB card was exactly same in these two amps. After I tried it the amplifier either not start or it goes in protect mode directly. Then i changed back to the original PCB cards and amplifier still keeps protect-mode or limit mode or dont start up at all. So I now ended up with 2 pcs broken amplifiers :( Is there any reset that need to be done when changing the pcb card or anyone got some tip for me? I really feel stupid :) ![]() ![]() |
geoSal ![]() Registered User ![]() ![]() Joined: 05 July 2011 Location: THESSALONIKI Status: Offline Points: 338 |
Ask DjLeco,I think he is the one that can help you out with this
DjLeco ![]() Young Croc ![]() Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 808 |
M4trix ![]() Registered User ![]() ![]() Joined: 23 June 2009 Location: Croatia Status: Offline Points: 422 |
I see you have uTorrent working. Are you downloading service manuals? ![]() |
Thanks for fast reply.
Now the issue with EV P 1200 is this: B channel working fine. A channel Limit light is constantly on and the music output plays but much lower then on Channel B. Any idea? Can I have broke someting when I switched the PCB cards? Was it a bad idea .. ? :( |
@serioussound, mate, first of all, do you have any experience with electronics, repairing stuff. If you don't have it, then there is no use giving you such tips. You'll make things even worse! Believe me, P1200 has high voltages (+/- 90V = 180V) and they can show you what does almighty big bang really mean. ![]() Edited by M4trix - 25 December 2015 at 8:02pm |
Not much experience probably I have to leave it for a professional.
But since the PCB cards was exatly same I thought it was risk-free to change. Maybe someone could give me a hint about what happend. / André |
According to the schematics, those control boards (those you switched) are identical. And here goes the part where you should have some experience with using multimeter. Something is tripping the protection circuit and that could be high DC on the channel output (blown output transistors as Leco showed), output transistors went out of SOA, overheating (overloading) issue, or the main transformer's thermal fuse is open due to overheating. There is another possibility, control circuit is damaged and it's tripping the output relay, the triac and the chopper transistor (J111) on the input. I'll leave the rest of possibilities to Leco.
Okok because before switching the control boards both amplifiers working.
So the problem must occured when I switch the boards? |
Maybe I got the cables on the PCB card wrong and that is what caused the problems?
Are you speaking about Dynacord L300? If yes, then it might be the problem with mixed connectors (wires).
![]() Edit: Anyways, I'll leave it to Leco. He had some problems with Dynacord and Electro Voice amplifiers. Edited by M4trix - 25 December 2015 at 8:57pm |
No I talk about the P 1200.
It worked fine before switching boards. The only issue was channel b was sometimes glapping when turn the amplifier on which was really annoying :) But all led indicators was light up as it should. And I thought to change the control board may should solve the issue .. |
Page 12> |
