EV P-1200 problem :( |
Page <12 |
M4trix ![]() Registered User ![]() ![]() Joined: 23 June 2009 Location: Croatia Status: Offline Points: 422 |
Now you confused me. You said after switching back the control board to Dynacord which was ok before that, isn't working anymore. Did you sort the problem or it's still there? As for the 'gapping' on P1200 ...heck, what does that mean? I can't find the word gapping in the dictionary!
![]() Edit: oops, I meant glapping. ![]() Edited by M4trix - 25 December 2015 at 9:14pm |
serioussound ![]() Registered User ![]() Joined: 01 December 2013 Status: Offline Points: 443 |
Sorry my english is bad!
1. Dynacord L300 was working perfet but I have no use for it so I wanted to use parts from it. EV P1200 works BUT sometimes when turn it on it have NO output on channel B. (Channel A always works perfectly. It starts up perfectly and lights coming off as it should just no sound output on channel B. Then when turn it off and on again sometimes the sound on channel A just "pops back". 2. Since I have no use for my Dynacord L300 I thought to change the controlboard to the EV P 1200 amp to see if this solved the issue on the EV p 1200 amp. 3. When put Dynacord control board into EV P 1200. The fuses pops and amp dont want to start. 4. I put the original EV P 1200 control board back into EV P 1200 again now both Channels have sound BUT Channel B limit lightning is CONSTANTLY ON and the output volume on channel B is much lower then on Channel A. 5. When put the Dynacord L 300 control board back into the Dynacord L 300 it goes into protecting mode. So I have ended up with 2 broken amplifier instead of 1 :( "glapping" is kind of swedish word for electricity or signal coming on and off from time to time cause of a bad connection somewhere. |
Well, one thing is for sure, you have made a great mess!
![]() ![]() Edited by M4trix - 25 December 2015 at 9:54pm |
Ok yes but the original EV P 1200 control board I never put into Dynacord.
So original EV P 1200 back in EV P 1200 I think its strange its not working :( I will let a professional take a look but its alway good to get dome answers from you guys here at first.. |
Yep, handing over to the repair shop is the best solution. Report back when it's done.
![]() Edited by M4trix - 25 December 2015 at 10:29pm |
Yes only need to find a decent guy in my country...
DjLeco ![]() Young Croc ![]() Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 808 |
If you were in Romania...
Canario1979 ![]() New Member ![]() Joined: 03 November 2022 Location: Spain Status: Offline Points: 2 |
Hello, I'm new here and I have problems with the EV p600, after lending it they returned it to me with the output leds on fixed. I have checked output transistors and everything is correct. some help? or any ideas?
full speed ![]() Registered User ![]() ![]() Joined: 20 January 2010 Status: Offline Points: 241 |
the relay clicks? disconect the amp from transformer if relay clicks the problem is on amp if not the problem is on soft start
Hola, el relé si conecta. la etapa final esta revisada y no hay transistores ni resistencias en mal estado. pero por las dos salidas de altavoces sale ruido, aun estando desconectado el anterior.
Hello, the relay does connect. the final stage is revised and there are no transistors or resistors in poor condition. but noise comes out of the two speaker outputs, even when the previous one is disconnected. |
the noise is like arc? or buz?is the capacitors all ok?is an old amp and caps must change.check the big filter capacitors and all the small ones.check if is a dry joints
Page <12 |
