  New Posts New Posts RSS Feed - EV TG7 AMPS
EV TG7 AMPS
TRE4U2NV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRE4U2NV Quote  Post ReplyReply Direct Link To This Post Topic: EV TG7 AMPS
    Posted: 14 May 2007 at 1:44am
Specifications HAS ANYONE HEARD OR TRIED THESE YET ?
Continuous rated power (1k Hz, THD 1%) 2Ω 3500 Watts
Continuous rated power (1k Hz, THD 1%) 4Ω 2500 Watts
Continuous rated power (1k Hz, THD 1%) 8Ω 1500 Watts
(20-20k Hz, THD<0,2%) 4Ω
2100 Watts
(20-20k Hz, THD<0,2%) 8Ω
1050 Watts
Maximum bridged output 4Ω 7000 Watts
Maximum bridged output 8Ω 5000 Watts
Slew Rate < 35 V / µs
Amplifier Gain (dB) 39dB, 35dB. 32dB (switchable)
Control Protocol CAN-Bus (with RCM26 module)
Network Control (IRIS-Net) Optional
Total harmonic distortion < 0.05 %
Intermodulation Distortion (SMTPE) < 0.05 %
DIM 30 < 0.02 %
Signal-to-noise ratio (A–weighted) < 111 dB
Input Impedance (balanced) 20 kΩ
Input Sensitivity 0 dBU/+6dBu/+7dBu (switchable)
Weight Net 14.5 kg ( 31.97 lbs )
Dimensions (HxWxD) 88.1 x 483 x 512 mm
(3.47" x 19.02" x 20.16")
Edited by TRE4U2NV - 14 May 2007 at 1:47am
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2007 at 10:18am
Yeah heard them get tested at Plasa 2006.
I can't say how cool or warm they run as I only heard them being tested for like 15 mins.
But they impressively drived the speaker stack there. And sounded crystal clear, clean and the bass was very tight and loud.
I forgot to ask how hard they were being driven into what impedance.
