  New Posts New Posts RSS Feed - Expanding Foam in Scoop
MINTEVENTRESOURCES View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MINTEVENTRESOURCES Quote  Post ReplyReply Direct Link To This Post Topic: Expanding Foam in Scoop
    Posted: 15 November 2017 at 10:53pm
Has anyone tried expanding foam in the scoop section of a scoop? (Under side of the scoop of course) What are the results?
Mint Event Resources
valve head777 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2017 at 10:56pm
YYeah, heard it was a good idea, stiffens the scoop and reduces any resonance in the void behind.....
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 9:35am
What if it breaks and starts flapping in there after some time .
A possibility....
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 9:52am
if the void is filled with expanding foam, it won't break.. it'll dense.
i do'nt have any scoops but i've done this behind all horn sections i have. like in mt121s and stuff.
it's a good thing to do.
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 10:06am
Used it in punishers before. Would definitely use it again. I could see it damping out a fair bit of resonance, but is no substitute for a properly braced expansion.
Do spent £10 on a proper applicator gun to attach to a can, you'll thank yourself later.
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 1:08pm
drill little hole bottom of cabinet make sure you don't use to much would bus thru
Post Options Post Options   Thanks (0) Thanks(0)   Quote valve head777 Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 2:46pm
Let it come out, set and then cut the excess off.
Used it in my old mid horns and improved the quality of sound. It won't break up if it's filled completely and adds nothing to the weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 10:01pm
Was going to say , yu need it to fully expand in the void, and yes let it come out so you its all filled
let dry and go hard cut excess off , little filler sand , job a gud'un
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 10:30pm
Builder friend says it actually conducts sound and makes things worse when trying to stop noise.
Make of that what you will, I'm not sure
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 10:43pm
...so why do they use it in house for heat AND sound insulation? I've seen people fill drywall with the stuff and it cuts down noise A LOT
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 16 November 2017 at 11:06pm
in our case though we're not using it to stop noise as such.. but to ad density and reduce resonances.
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2017 at 6:04am
So your friend thinks.. foam conducts sound better than pure air? :D
