Extended CB-18 Cyclops |
Page <1 23456 17> |
adrianm ![]() New Member ![]() ![]() Joined: 08 May 2009 Location: Philippines Status: Offline Points: 1 |
hi streetsounds, 2 questions which one has a higher spl, your cb18 or the subzero?
which one has a deeper bass, cb18 or subzero?
streetsounds ![]() Registered User ![]() Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
These CBe-18s will definitely outrun the subzero with regards to SPL and musicality. It can also go deeper.
Bass matters...
jollygt78 ![]() Registered User ![]() Joined: 22 March 2006 Location: United States Status: Offline Points: 138 |
how would these compare to say a dual 18 reflex with the same drivers?
Im not a reflex user so I dont have that much idea how to compare these cyclops to the reflex bins, but I think these CBe-18s, recalling from what Ive heard from a reflex cabs before, are far better spl wise.
Bass matters...
gabegeforce ![]() New Member ![]() Joined: 16 January 2011 Location: PH Status: Offline Points: 1 |
hi, the baffle itself is very neat. can you post the plans? is it autocad format?
Thanks, I posted the link on page 3, you just need to download it.
Bass matters...
Two more additional Extended Cyclops bins, finally completed
![]() ![]() ![]() ![]() Edited by streetsounds - 20 January 2011 at 1:08pm |
Bass matters...
staiper ![]() Registered User ![]() ![]() Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
Hello Frad,
It grooooows ![]() Wanted to ask some question which may also be interesting for other CB-18 owners/builders. As you already have pretty neat stack of CB's and worked with them on real gigs what is your opinion about CB-18 bass "directivity/throw" .. one of builders have have said that he have pretty nice front-to rear SPL difference described as almost "cardioid" bass coverage with them so I wanted to ask you if you have any observations regarding this. Best wishes Edited by staiper - 20 January 2011 at 2:21pm |
Just do it! ..or do not.. ;)
Well I think the same with me here very good throw at front, waste no sound at back and at sides..but just enough for the band to feel that something is pounding hard and heavy at the front. Ive used them just 2/side in an almost 2 basketball court size semi open gym and still can cope. One more thing ive notice unlike with previous bins that ive used, stacking them in stereo, the bass is almost even at any point at the front, it seems as if you stack them all together at center.. so I think the other builder that you are mentioning is quite right. Now I will try 3 per side and see hows its like
Bass matters...
rish ![]() Young Croc ![]() ![]() Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
Hi guys. sorry to butt in but i have 2 faital pro 18hp1020 drivers and was wondering if this driver will work well in the cyclops. i really like the design . thanks to STAIPER. |
SIMon says that Faital Pro 18HP1020 will work excellent in CB-18 (any version) |
Powersoft ![]() Registered User ![]() Joined: 18 December 2005 Location: Slovenia Status: Offline Points: 19 |
Nice build. Are there any specs of all this 3 types of CB-18 cabs? I'm interested in building some but would like to now their usable pass band and sensitivity.
Also the tapped horn design as far I'm aware of does not couple (like a normal folded horn) when used in multiples. Is this true? Edited by Powersoft - 20 January 2011 at 5:02pm |
Page <1 23456 17> |
