Extended CB-18 Cyclops |
Post Reply | Page <1 1213141516 17> |
hardtechnic
New Member Joined: 06 October 2013 Status: Offline Points: 5 |
hi guys i'm new in this forum and i start to build my system in this moment i have 2 RCF L18P300, 1x Eminence Omega 18, 2 X Electro Voice DL15BFH want to ask you about RCF L18P300 and Eminence Omega 18 it is suitable drivers for this box? if can give me some advice for my system i will be very thankful. my ideas is Top 2x MT 121 2xHD215 and 4XCyclops?
LesterNic
New Member Joined: 02 January 2014 Location: Nicaragua Status: Offline Points: 1 |
Hi happy new year to all ... My question is if I can use a RCF-L18P400 a CBX-18 Ciclops, and is the recommended frequency ...
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Hey, is there some simulations around for this? Would be quite nice:-)
tv00
Answer to my own question, here's a link to Staipers simulation and another, perhaps more realistic one by Djim:
http://www.diyaudio.com/forums/subwoofers/202826-4-cbe-18s-6-ss15s.html |
jazzg
New Member Joined: 09 June 2012 Location: arad Status: Offline Points: 1 |
I want to build a Cyclops CBe-18.
Can i use beyma 18SW1600Nd speaker? |
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 921 |
Sure you can ,its pretty similar to the b&c tbx100 which is designers no1 choice as i noticed. Should even outplay it easily.
Also i think this design i quite forgivable on driver choice. Tried a pd1850 out of fun,as you would expect the sound was a bit cold and hard but the spl was scoop like . All depends on what ur after and im sure the beyma will rock in the cyclops. Edited by Sypa - 26 July 2015 at 7:27pm |
tv00
Any link to the simulations for all three versions?
I'm wondering how rcf lf18x451 will do, a bit cheaper than b&c sw115, but similar in performance with regards to xmax & aes rating.. -I know I posted links above, it's pretty good and there's another link on the page before, just seems like there's no new realistic sim for the cbx, only th cbe, perhaps I should go to diy thread and solve it. SUGGESTION: It's seems to be a evergoing problem to find newest simulations & mods in the long threads about speaker designs (I've spent hours in the Xco1 th-18 & invader thread) Wouldn't it be a nice idea to open a WIKI where we could all update the wiki with new sims & mods? Guess I could have it setup! Edited by tv00 - 03 October 2015 at 11:47am |
boombapbassbins
New Member Joined: 11 March 2016 Location: enfield Status: Offline Points: 2 |
hello party people, i know this thread is from a while back but would any of you have the CBX extended plan at all?
all i've found on the internet is low quality jpeg's were i cant actually read the measurements. much appreciated |
willy.gray
Registered User Joined: 27 July 2010 Status: Offline Points: 141 |
It's on hornplans. Hornplans.free.fr/cb18_Cyclops.html
boombapbassbins
thanks dude :)
Rohan
New Member Joined: 31 July 2013 Location: india Status: Offline Points: 3 |
what is the exact hpf n lpf frequency for cyclops extended......
im useing 30 hz lr 24 140 hz bw 24 gain 0db im useing p audio sd 18 el 1700 watts is the polarity need to be reversed
streetsounds
Registered User Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
35hz setting would be ok for the hpf..you will have enough mechanical protection for your woofer..but I normal go 40hz especially when Im using more than 2 bins. 140hz for the lpf is fine.
Bass matters...
