  New Posts New Posts RSS Feed - Extended CB-18 Cyclops
 Post Reply Post Reply Page  <1 1213141516>
hardtechnic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardtechnic Quote  Post ReplyReply Direct Link To This Post Posted: 06 October 2013 at 5:05pm
hi guys i'm new in this forum and i start to build my system in this moment i have 2 RCF L18P300, 1x Eminence Omega 18, 2 X Electro Voice DL15BFH  want to ask you about RCF L18P300 and Eminence Omega 18 it is suitable drivers for this box? if can give me some advice for my system i will be very thankful. my ideas is Top 2x MT 121 2xHD215 and 4XCyclops?
LesterNic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LesterNic Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2014 at 1:57pm
Hi happy new year to all ... My question is if I can use a RCF-L18P400 a CBX-18 Ciclops, and is the recommended frequency ...Shocked
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2015 at 10:30pm
Hey, is there some simulations around for this? Would be quite nice:-)
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2015 at 10:33pm
Answer to my own question, here's a link to Staipers simulation and another, perhaps more realistic one by Djim:
http://www.diyaudio.com/forums/subwoofers/202826-4-cbe-18s-6-ss15s.html
jazzg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzg Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2015 at 10:32am
I want to build a Cyclops CBe-18.
Can i use beyma 18SW1600Nd speaker?
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 26 July 2015 at 7:22pm
Sure you can ,its pretty similar to the b&c tbx100 which is designers no1 choice as i noticed. Should even outplay it easily.
Also i think this design i quite forgivable on driver choice. Tried a pd1850 out of fun,as you would expect the sound was a bit cold and hard but the spl was scoop like LOL . All depends on what ur after and im sure the beyma will rock in the cyclops.
Edited by Sypa - 26 July 2015 at 7:27pm
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2015 at 11:11am
Any link to the simulations for all three versions?
I'm wondering how rcf lf18x451 will do, a bit cheaper than b&c sw115, but similar in performance with regards to xmax & aes rating..
-I know I posted links above, it's pretty good and there's another link on the page before, just seems like there's no new realistic sim for the cbx, only th cbe, perhaps I should go to diy thread and solve it.
SUGGESTION:
It's seems to be a evergoing problem to find newest simulations & mods in the long threads about speaker designs (I've spent hours in the Xco1 th-18 & invader thread)
Wouldn't it be a nice idea to open a WIKI where we could all update the wiki with new sims & mods? Guess I could have it setup!
Edited by tv00 - 03 October 2015 at 11:47am
boombapbassbins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boombapbassbins Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2016 at 4:10pm
hello party people, i know this thread is from a while back but would any of you have the CBX extended plan at all?
all i've found on the internet is low quality jpeg's were i cant actually read the measurements.
much appreciated Tongue
willy.gray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote willy.gray Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2016 at 5:11pm
It's on hornplans. Hornplans.free.fr/cb18_Cyclops.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote boombapbassbins Quote  Post ReplyReply Direct Link To This Post Posted: 11 March 2016 at 5:15pm
thanks dude :)
Rohan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rohan Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2016 at 1:29pm
what is the exact hpf n lpf frequency for cyclops extended......
im useing
30 hz lr 24 140 hz bw 24 gain 0db
 im useing p audio sd 18 el 1700 watts is the polarity need to be reversed
streetsounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote streetsounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2016 at 10:03am
35hz setting would be ok for the hpf..you will have enough mechanical protection for your woofer..but I normal go 40hz especially when Im using more than 2 bins. 140hz for the lpf is fine.
Bass matters...
