  New Posts New Posts RSS Feed - Extreme power handling of a PD1850
 Post Reply Post Reply Page  <1234 6>
Bassaddict View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassaddict Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:15pm
was only a bridged Yam P5000
I know they arnt great for bass, but it is all i had budget for at the time.
and i have never measured the actual ouptut of it, was only going from paper specs.
The only good system is a sound system.
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:15pm
Originally posted by cilla.scope cilla.scope wrote:
Im with Mr Wilkes on this one,  at 2K rms,  PD186 would melt.
+1
+2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassaddict Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:16pm
testing the cab itself i did use a sine wave generator running the amp just under clip
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:17pm
I've had 2x PD186 across Proline 2700 in Bridge.
EDIT:In theory that's 3200W across the pair in 4 ohm bridge.
In reality, it wasn't a sine wave, and the amp wasn't being given 0db, and the amp wasn't just on clip... So in short they were'nt being fed 3600W.
Easy to get carried away with these figures...
Edited by levyte357 - 26 January 2010 at 3:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassaddict Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:19pm
@ Lev
the cab would be 6th order BP, playing anything from dubstep to live bands 35Hz to 120Hz
HPF L/R set @ 35Hz
cilla.scope View Drop Down
Legs all the way to her bottom....
Post Options Post Options   Thanks (0) Thanks(0)   Quote cilla.scope Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:26pm
The rated power of a Yam P5000 bridged into 4R is only 2600W peak for 20ms  the RMS power will be way lower.
the RMS power into 4R per channel is probaly as close as makes no difference to what it delivers bridged (they dont even rate it for bridged into 4R as I presume you have 8R drivers and rand them in parallel across the bridged output ...  so about 750W RMS, which is about right for what the driver claims to handle and is consistent with a peak rating of 2600W peak and a 3.something to 1 crest factor.
So .. no, you didn't run 2600W rms into a pair :)
My girlfriend thinks I'm a stalker.
Well, she's not exactly my girlfriend yet ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:28pm
@ Lev
HPF L/R set @ 35Hz
Understood, but that still isn't continous power guv, it's music power.
If you take  an amplifier capable of supplying 1.5kw into 8 ohms, when fed a 40hz sine wave, and  attach PD186 across it, in cab perfectly tuned for it, you will see the driver die long before the amp is at full tilt. Probaby due to suspension giving up before, voice coil.
There are very few amps that can truly supply their stated continous power, and even fewer drivers that can withstand theirs. WinISD is sometimes "very accurate" here.
Which makes me laugh when I see some driver manufacturers stating 2kw-3kw "anywhere" on their spec sheet.
Edited by levyte357 - 26 January 2010 at 3:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote cilla.scope Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:30pm
@ Lev
HPF L/R set @ 35Hz
at 35Hz, bridged into 4R the Yam P5000s doesnt even manage a whole cycle of 35Hz at 2600W peak .. 20ms equates to a single cycle of 50Hz  ... bridged into 4 it probably provides about 1500W RMS, 750W per speaker for  2 x 8R in parallel, dependign on crest factor, could be less.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:34pm
i one bridged an Inf 8MK2 into a pair of PD186 n they took it alll night looong baby Big smile
by the end the mp was smoking LOL
sorry way too much coffee
Post Options Post Options   Thanks (0) Thanks(0)   Quote cilla.scope Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 3:42pm
Ah, I can see Mr and Mrs Reallity aren't in right now,  I'll come back later. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassaddict Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 4:02pm
fair nuf i stand corrected.
i dont know the ins and outs of amps. just going from how we run our systems and from my experience.
so lamens terms for me please,
I do want to learn about the amp internals alot more. and have already made a start, be it a slow start it is still a start.
so basically you are saying if i happend to get my hands on an amp that gave a true RMS rate of power say 800w
i could stick a PD1850 on it and be happy?
but if i had an amp that gave 1600w RMS all night long it would probably fry the 1850?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2010 at 4:36pm
Have personally seen CA18/MA5000Z (on 16A supply), drive 2x PD1850s per channel quite excellently.
Have heard a pair across  bridged MPX1200, 4050HD, MA2400,  which provided more SPL especially at the extreme lows, but ran greater risk of damage to the drivers.
Quality, amp will do the job @ 4 ohm stereo with nice sound quality... (There you go ArthurGEmbarrassed)
And if you want insanity, then...
