extremely high efficiency |
Page 123 4> |
teeth ![]() Registered User ![]() Joined: 05 July 2021 Status: Offline Points: 394 |
![]() ![]() ![]() ![]() ![]() Posted: 03 May 2023 at 10:42am |
after a late night narcotics fuelled chat with a friend, think we are going to try and design (and possibly build? lets see!) a really highly efficient system (including amps too, making another thread on the amp forum if that's your thing) so i'm scouting out some very high efficiency designs across the bands. what are your favourites? plans, but would also be interested in commercial stuff if anything comes to mind. |
some of my thoughts here: horns/folded horns/tapped horns i've actually not found a design out there with someone declaring it to be "really efficient" as a design principle despite the nature of horns themselves. paraflex? i'm still finding it very hard to unpick if they are any good or not, but looking at the design, they do look like they have potential to be highly efficient MEH/synergy/syntripp/unity horns - don't know enough to comment but i think a reasonable mid/high choice here 18sound AMT200P air motion - got a questionmark next to this one in my notebook, i don't know enough about it though... |
haven't touched on drivers either which will obviously play a huge part in any efficiency gains!
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 7001 |
If you can still find them, ATC made some of the most efficient drivers around. I have them in my Philishaves. If you don't mind the weight, IMHO, one of the most efficient - and best sounding mid-cabinets ever made.
![]() Edited by Earplug - 03 May 2023 at 11:16am |
bob4 ![]() Old Croc ![]() ![]() Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1779 |
Probably Danley...... they have been doing designs for a long time that attempt to combine the output of multople transducers as coherently and constructively as possible.
Maybe have a look at the various Danlry patents? The amount of transducers they cram into one loudspeaker are astounding..... for example the Jericho series
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3059 |
some discussion of high efficiency bass horns here:
https://forum.speakerplans.com/hyperbolic-bass-horns_topic105331_page2.html |
DMorison ![]() Old Croc ![]() Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1580 |
Depends how big/heavy you can tolerate.
Peter Morris's PM60/90 were designed to be about the loudest thing he could get to sensibly be pole mounted for example, with the BMS coax high-mid and high driver plus 2 horn loaded 12's. Design threads with plans over at soundforums.net
Bams ![]() Young Croc ![]() Joined: 08 April 2009 Status: Offline Points: 585 |
well.. as far as extreme and high efficiency go....
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7707 |
Actually considering the number of drivers inside, Danley boxes are more power hungry than efficient. From 90Hz up there are many more efficient (amp friendly) and more compact boxes to be found. The OP is not disclosing the size of the rig he want to build. So that info should help too.
kipman725 ![]() Registered User ![]() Joined: 02 September 2020 Location: Warrington Status: Offline Points: 221 |
The Danley J8 has extremely high sensitivity: Low 119dB | Mid 120dB | High 119dB (measured as 28.3V @10m) I would guess those these numbers are exaggerated by the lower than 8 ohm impedance so would be: Low 110dB | Mid 117dB | High 116dB if adjusted for their nominal impedance's to '1W/1m'. Still higher than any other box I know of. I've been looking into its tweeter arrangement and it does not seem too difficult to replicate: |
Phil B ![]() Old Croc ![]() ![]() Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2311 |
We went down the Tapped horn and Unity path for our off-grid setup for efficincy, running off solar means you need the biggest bang for the least power draw! Barn doors get you greater directivity and forward gain. Getting our own design Unity horn was quite a journey but they are def' worth the effort. I would look at the Syntripp design over on D.I.Y Audio forum ...extremely simple , light weight and very efficient ? We built a couple for a venue here in Melbourne and they are great small two way boxes... All my ramblings and builds are over on the 12v section here on SP ...
.p. |
fudge22 ![]() New Member ![]() Joined: 26 July 2022 Location: UK Status: Offline Points: 7 |
If you are looking to maximise efficiency, you need to think
outside the box. Ronald Aarts et al: High-Efficiency Low-Bl Loudspeakers Efficient Resonant Loudspeakers with Large Form-Factor
Design Freedom Direct-Radiator Loudspeaker Systems with High Bl Don Keele: Comparison of Direct-Radiator Loudspeaker System Nominal
Power Efficiency vs. True Efficiency with High-Bl Drivers Efficiency comparison between low frequency horns and direct
radiators. Maximum Efficiency of Direct-Radiator Loudspeakers Maximum Efficiency of Compression Drivers It won’t hurt to gen up on the terminology. There is more to
acoustics than spl. While Olson usually gets the kudos for his book Acoustical
Engineering, I would recommend Acoustics by Beranek. |
Page 123 4> |
