FANE 12-250tc FULL RANGERS |
Post Reply | Page <12345 19> |
Andy Kos
Its a 250W 12" driver... Its hardly going to shake the floor! |
Earplug
One track mind! I´d say this driver would be more suitable for an instument cab, ie keyboards or guitar. Not really PA. |
Andy Kos
This style of speaker works quite well as simple disco speaker, back in the 90s Deltec used to make bucketloads of 1 x 12" + piezo speakers using the eminence equivalent. For a simple DJ set up, for pub gigs, it's a very cost effective solution.
As soon as you have 2 drive units and a passive crossover, costs start going up.
DMorison
OP was asking about drivers to go over 1x18 vented bass bins - so absolutely no need for low end.
Earplug
Yes, most probably better than some of the (red) plastic crap out there - but people are generally deafer these days, so need the HF distortion, otherwise it won´t sound right!
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
edit.nothing
Edited by app - 30 November 2014 at 5:17pm |
"what!?"
bob4
wow, nice find app!
I wonder about the dispersion in the HF range.....
dang, it would be tempting to put 2-3 of those stacked vertically in a box and see what happens :) app, you might have a budget winner for your homebrew sound stick it in a closed box and see what happens :) this thing might even work in HiFi use as a dipole...... |
bob4
taking a closer look at the datasheet, the frequency plot looks weird.... does this thing really have a 108-109 dB sensitivity around 10k? That's CRAZY!
Andy Kos
Would be an interesting test... Two vertically works OK I have tried that myself - I think the issue is more horizontally with multiple cabs. and I say, 'usually', in that I was told this some time ago by someone who said they had tried it with poor results, but perhaps their expectations were too high from the HF, I havent tried it myself, but i do know the off axis response isnt amazing, so potentially going to have hots spots with a horizontal array, but a vertical array may well improve things.. |
nickyburnell
What about vertically but with slightly left right (splayed) top and bottom baffles. IE a 2x12 but each driver a few degrees each way horizontally?
bob4
it's goin to make the whole shebang lobe diagonally...... it will probably also decrease coupling in the HF it's all guesswork as long as there is no reliable information about the HF dispersion angle! EDIT: AndyKos, about that HF dispersion angle..... you got any idea? Edited by bob4 - 01 December 2014 at 9:31am |
splodge360
Registered User Joined: 15 September 2007 Location: East London Status: Offline Points: 88 |
Sounds like a 12" version of a tall bose 502 speaker array would make a good cab design for hf angles. If the speaker is run full range, then the hf graph must odd if the starting point is moving in and out at 30 hertz.
LineArrayHire
