FANE 12-250tc FULL RANGERS |
Post Reply | Page <1 45678 19> |
bob4
......and make them trapezoidal.....
sorry for the crude model, it's just a quick doodle with my very basic sketchup skills front: 40cm wide, 35 cm high back: 20 cm wide, 35 cm high 35 cm deep -> ~14° angle on each side -> maximum splay with two cabs side by side ~30 ° -> volume ~36 l |
app
Old Croc Joined: 26 December 2013 Location: Finland Status: Offline Points: 2435 |
Dude youve done some mad work or have a lot of extra time Thanks a lot! I just dont have the tools to make angled cuts so this kinda design is "impossible" for me to do.I could use a file but... There are many other people who can use your design so no worries,nice work Ill play with winisd and see what size would be "best". Thanks for the 70 vs 40l comparison. Ill just build a simple boring traditional box I might make it a bit smaller,thanks for the tip! Respect! |
"what!?"
bob4
thanks
Earplug
"I just dont have the tools to make angled cuts so this kinda design is "impossible" for me to do.I could use a file but..."
You don´t have a circular saw? |
app
May come as a surprise to you but errm,no! |
"what!?"
all bass
You don't have a single family member or neighbour that could lend you one? It would make things a lot easyer.
app
Yeah!
So far Ive used the sawing service at the wood shop so Ive only cut the holes for the driver with jigsaw. I need to ask if the guys at the wood shop can they do angled cuts with their big machine,they propably can... edit.If they can do the cuts Ill do the bob412"s Edited by app - 15 December 2014 at 9:48pm |
"what!?"
mini-mad
If its a "wall saw" more likely they cant... but for a very small outlay i would be worth investing in a circular saw. Using a straight bit of timber will cut straight lines quite well and with a bit if practice with do angle cuts nicely too.
My plunge saw set me back 150 but thats because i had 150 to throw at it. Iv even ( a very long time ago) i built a jig/clamp system that i could use a belt sander on for angles. Not great, not ideal but it did work. |
app
Its looks about something like this!
edit.Ill find out tomorrow! Edited by app - 15 December 2014 at 10:03pm |
"what!?"
mini-mad
Your good to go son.... that bad boy WILL do angles!
app
My monkey brain has come up with following cutlist in cm: front-40x35 back-20x35 (with 3cm front piece sinkin and 1,5mm ply) sides- 41x41 top&bottom 20x40x41 Help a fellow monkey out and tell me have I got the pieces right |
"what!?"
bob4
gimme some time, I'll come up with a cutlist.....
