Fane 2x12 Mid Horn |
Page 12> |
Chris LDN ![]() Registered User ![]() Joined: 03 June 2011 Status: Offline Points: 74 |
![]() ![]() ![]() ![]() ![]() Posted: 12 August 2021 at 2:57pm |
Has anyone built, or heard the 2x12 mid horn, on pages 40-41, of the Fane "Loudspeaker Enclosure Design and Construction" book?
Link to the plan here: http://hornplans.free.fr/2x12%20front%20horn%20loaded.jpg Interested to hear what anyone thinks, if anyone's done any Hornresp simulations, if you've heard them, or built them? Lots of dodgy angles though - might make the build difficult. |
Also, what drivers would people recommend, if I were to build some today?
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Online Points: 7421 |
Old, old design.
Not sure of your desired resp range, but Would suggest MT121s, loaded with B&Cs, 18sound or PDs, and they will do 160hz to 1200hz (with flattening eq), no problem. 2" above that, with large horn, for industrial strength tops, that can cover 2000ppl, inside or out, with 6x cabs.
I am looking to build eight of the half width Jensen Imperial's, that another forum member here built ten years ago. Looking to see if there's life in some of the old designs.
Crossover at 200 Hz, to the mids, with a possible exit at 1 kHz. The plans aren't set in stone, and the bass cabs will be built first. So looking to collect opinions, thoughts, etc. - especially if anyone has heard them, or built them. Absolutely no information on here about them, aside from one thread, years ago. |
If also interested in how low they could go, in a stack three high? More for curiosity, than anything else.
Tinnitus Rex ![]() Registered User ![]() Joined: 31 October 2020 Status: Online Points: 252 |
Whatever internal design you pick,dont make them with crazy external angles.
"couldn't we just like... use headphones?"
Yes, I like the martin 115/215 bins. That's why using a similar cab for mids has my interest. Also wondering if a stack of three high, might play low enough, with judicial driver selection, to be sufficient on kick heavy music, to form a not so micro, "micro stack". Think funk, R&B, soul, etc.
Otherwise, still interested on how they will sound for mids - vocals, especially. |
Above 100 Hz Three high of anything creates vertical cancelations that often outway any benefits.Point source power density is a better direction .
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10640 |
https://www.hometheatershack.com/threads/hornresp-for-dum-hmm-everyone.36532/ Have at it. There's not a lot to the design, although take any data from Hornresp >1000 Hz with a pinch of salt. |
doller ![]() Registered User ![]() Joined: 19 July 2014 Location: japan Status: Offline Points: 487 |
Hi Chris, I had a go at one of the old fane book designs. I chopped and hacked it a bit. I was just looking through the book and knocked it up one in a morning, I think. J
ust to hear what it sounded like. It was pretty ok. So I made another one looking like the pic just because I could. I really like how they sound I have 4x and taken them to a fare few gigs now never had anything other compliments. I do do mainly tekno and psy gigs maybe why. But I really like how the voice sounds . Just my experience. I would say knock up one with cheap ply or mdf and have a listen you might like it. |
APW ![]() Young Croc ![]() ![]() Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1081 |
cool!!
Unfortunately, Hornresp is limited to the Windows operating system - which I don't use, nor do I know anyone personally who does (unless they're keeping it a tight secret). Can't use Wine, as I'm not using an x86/x64 device either. If I knew the step by step maths Hornresp uses, I could knock up something myself, but the author doesn't want to divulge, last time I looked. It's a shame, as reading the history of Hornresp, the author created the original in Fortran - so he would be able to release a cross platform version, if he so desired.
Hi dollar - that looks fantastic! Well done. I think I will take your advice, and build one or two, just to see for myself. The Fane book states it's a 1.2 sheet affair, so shouldn't take too long. I'm still open to other peoples thoughts, and ideas though. Just in case anyone else reading this, is thinking case closed, thread locked. No... |
Page 12> |
