Fane CD 145 diaphragm 16 ohm. |
Post Reply | Page <12 |
Natedub
Registered User Joined: 07 January 2013 Status: Offline Points: 126 |
In fact I got mine from the exact same seller, fitted fine
funkyparrot
Young Croc Joined: 12 December 2010 Location: Leicestershire Status: Offline Points: 860 |
Hiya Nate. Perhaps I'm worrying unduly about the 150s, it's good to hear that someone has a positive review about them but, you can even see in that photo, that the holes in that EV replacement aren't big enough.
Natedub
Yes I agree the EV replacements dont look good! I dont think you will be disapointed with the cd150n diaphragms though mate
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 539 |
The one I ordered is going in a NCA box the other box of the pair is fine so will do a A/B comparison. Fingers crossed.
funkyparrot
Hi.KDW. You've not yet given a follow up on your diaphragm. I've received mine, they both look fine, but one had a 16ohm label on its package, the other one didn't, so I put the meter on it..... Meter on the 16 ohm reads around 15, so no prob with that one. Just the hassle of arranging return again!
I'm not fitting them immediately, these were only ordered as contingency stock
As far as the DH2 one goes, it was required immediately, that's been returned and I've found a genuine EV, but it was £97! At least I know it will fit. |
KDW32
Hi, mine arrived on Monday and looked fine, identical. It was labelled 16 ohm. even the little red paint mark on the positive was identical to the original. I wont be able to do the A/B test till Sunday or Monday. Will post again in this thread then. Cheers.
Hemisphere
Getting the mounting hole dimensions wrong seems such an elementary error that it probably isn't connected with poor worksmanship. Either it's an old version of the same driver or a very similar variant which was mislabelled by the seller.
KDW32
Sorry for the late reply. It sounds identical to the original Fane.
