Forum Home Forum Home > General > Wanted
  New Posts New Posts RSS Feed - Fane CD280 Diaphragm
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Topic: Fane CD280 Diaphragm
    Posted: 29 July 2019 at 3:38pm
One of the above needed.
100% Earth Moving Bass
colint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2019 at 8:46pm
The driver is made by P-audio if you ring Blue aran they can tell you which driver it is and supply the diaphragm
Edited by colint - 29 July 2019 at 8:47pm
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2019 at 9:21pm
Yeah it’s a P audio 750 something? I seem to remember. The diaphragm BA does is showing as out of stock.
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2019 at 1:13pm
Hi Gaz, did you have any luck with this? I find myself in the same boat as you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote colint Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2019 at 6:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2019 at 7:36pm
Not in stock Colin.
GAZ. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GAZ. Quote  Post ReplyReply Direct Link To This Post Posted: 13 August 2019 at 7:38pm
I contacted blue aran the other week, they say the diaphragms are on back order till October. At least they are still available seeing as I have 8 CD 280’s
I’ve not found anyone else that has them so just got to wait.
