Fane Colossus 18XB in Supers |
r.G
Registered User Joined: 23 April 2015 Location: Germany Status: Offline Points: 64 |
Posted: 24 October 2016 at 10:25pm |
Hi,
what are recommended xover settings for supers loaded with Fane Colossus 18XBs in a stack of two? Also, what EQing should be applied to get the most out of them? There are alot of different statements on how much power they can handle, but how much can they actually safely handle on roots & dub, what limiters should I apply? Thanks r.G
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Some of your questions are abit vague and very objective. Eq your scoops to your ears. Tune them to how you like the bass to be. Crossover points will be the same. Most people will say somewhere from 35hz - 90hz. Play around and see what works best for you
r.G
Alright, I forgot to mention that HD15s with Kappa 15 LFAs take over where the scoops roll off. I will try to eq them to taste, but somewhere on here I read that a slight 2-3dB boost at 45Hz and 63Hz is what you want. Which filters and slopes would you advise when crossing over scoops(and HD15s)? As steep as possible hpf at 35/38 Hz? Thanks r.G
r.G
Any advice?
