  New Posts New Posts RSS Feed - Fane Colossus studio 400watt
mass audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mass audio Quote  Post ReplyReply Direct Link To This Post Topic: Fane Colossus studio 400watt
    Posted: 20 June 2005 at 11:40pm
Would this speaker be able to work in a X1 enclosure, i can put as much as 1500watts into this speaker. (I have only ever got this speaker to work in a big fane horn loaded box if this project does not work they got to go), these are the parameters that i colud find
Brand Fane
Model COLOS 18 BASS
Description Cast frame, paper cone and textile surround
Range / type Woofer
Typical use Undetermined
Recomended enclosure
Series
Manufacturer
Order nr
Production status Undeterm.
Nom. diamerer [inch] 18
Vas [Liters] 209
Qts 0,3607
Qes 0,41
Qms 3
Fs [Hz] 34,5
Sensitivity [dB] 95
Max Power [W] 400
Power definition
Lower freq [Hz]
Upper freq [Hz]
Rec. Filter freq [Hz]
xmax [mm] 7,2
Moving mass [g] 185,91
Disp area [m2] 0,1142
Disp Vol [cm3]
xdamage [mm]
Air gap [mm]
Coil height [mm]
Coil diameter [mm]
Cms [mm/N]
Rms [N*s/m]
Magnet weight [gr]
Magnet height [mm]
Magnet diameter [mm]
Magnet material -
Re [ohm] 6,1
Z [ohm]
L [mH] 0,73
Bl [Tm] 24,487
Magnetic flux [Wb]
Flux density [T]
Outer diam. [mm]
Bolt circle [mm]
Nr of bolts [Nr]
Cutout [mm]
Weight [Kg]
Height [mm]
Depth [mm]
Driver volume [Liters]
Frequency SPL / Z
Home page [URL] http://www.fane-acoustics.com
Data sheet [URL}
Enterd by -
Date reviewed 2003-08-28
Date added 2003-08-28
Edited by mass audio
m.a.s.s audio(musically advanced sound system)
This page was generated in 1.406 seconds.
