Fane Folded Horn 15'' driver advise |
Post Reply | Page <1 3456> |
Biggus
Young Croc Joined: 02 May 2010 Location: Market Harborou Status: Offline Points: 1284 |
are they the fane w bins?
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2296 |
Yep, the simple single-fold 15"
I love the look of them... |
Dub Specialist Sound
same here mr bit, got a soft spot for the old w bins man
nice :-)
beatdancer
New Member Joined: 21 July 2017 Location: Germany, NUE Status: Offline Points: 6 |
Hey everybody,
i feel free to reactived this thread with a question. which controller setup you use for this cab? i actually can call two my own and i´m trying a little bit but i think, there can be more :) loaded with "Mivoc MPA SWA 15100 C8" ( https://www.mivoc.com/gs/product_info.php?info=p109_mpa-swa-15100-c8.html ) i like the sound and the nice punch ;) greetings from germany, daniel |
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 560 |
How do you mean?
The first page of this thread recommends using them from 60Hz up, any other settings are going to depend more on the drivers you have in them and the other cabinets you are using them with. |
beatdancer
hey roadrunner,
i am even interested in the delay settings for the tops and where is it good to tweak a little bit the EQ. thanks a lot |
RoadRunnersDust
Thanks(1)
That depends entirely on your tops and personal preference, it's not something someone can tell you over the internet.
Your best bet would be to find somebody local to you that knows how SMAART works and get them to set your delays and EQ to give you something to start from |
beatdancer
i am interested to put the pd1550 into it. somebody already said, that it will be pretty good. and i got a question to you: fane 15 vs hd15 - how will be the difference between this two cabs? best regards, daniel
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2460 |
I had 4 of these exact bins loaded with PD154s and they would kick like a mule. Great for house/techno. Take it first hand loaded properly these cabs will do you proud. Even kappa LFs would work well if the budget won’t stretch to PDs.
beatdancer
alright, thank you all for the advise - they sound pretty fine with pd 1550 :) the next quesion goes to power handling.i got the Thomann TSA 4-1300 and a Zeck PT 7 - DCX 2496 Controller - almost everytime with a A&H Xone DJ-Mixer tsa 4-1300 // 1220w 8 ohm per channel / 1670w 4 ohm per channel zeck pt 7 // 1400w 8 ohm in bridge mode / ????w 4 Ohm in bridge mode what you think will be the best match and how much power? best regards, daniel Edited by beatdancer - 13 December 2018 at 4:59pm |
djeddie
oops... see post below Edited by djeddie - 13 December 2018 at 8:34pm |
djeddie
