  New Posts New Posts RSS Feed - FANE PRIME 18XS 2x18 reflex box
Aurora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aurora Quote  Post ReplyReply Direct Link To This Post Topic: FANE PRIME 18XS 2x18 reflex box
    Posted: 06 December 2022 at 11:35pm
Hi guys looking into designs for the fane prime 18xs, i've heard it works well in a G SUB but given the box was built for drivers around 600w each at the time will it be a suitable box given drivers nowadays are now 1000w plus each? Also considered the B&C sub18 but making it 2x18 instead, would the G sub benefit from being modified to accomodate the modern more powerful drivers? Interested in thoughts!
Edited by Aurora - 06 December 2022 at 11:36pm
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2022 at 12:03pm
yes indeed do not build the g sub , it is pants, the b n c design will walk all over it ,have tested the 2 side by side tho we had single b n c cabs not a double its one my fav reflex free plans tbh :) make sure you brace it well tho, them drivers really move some air
Edited by paulus - 07 December 2022 at 12:03pm
TRENDSETTER SOUND SYSTEM
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2022 at 12:05pm
I've got a B&C Sub18 (the older shelf port design)
Loaded with a B&C 18DS115-4ohm  and powered from a Powersoft X4 and it's really really decent
So yes, build a double one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aurora Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2022 at 12:01am
Thanks guys will look into the SUB18 design more, I did notice it has a distinct lack of bracing though which is a bit odd for a sub design!!
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2022 at 9:32am
You got to work out your own bracing on many free designs.. and handles etc..
Reverence Sound system
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2022 at 10:03am
Why not Fane's own suggestion?
It's not as easy to build, but 100% designed for your drivers 🙂
