Fane scaled up |
Post Reply | Page <1 45678 13> |
mykey-
Old Croc Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6114 |
Build it and let us know Edited by mykey- - 04 February 2013 at 1:58pm |
ennayess
Registered User Joined: 08 April 2010 Location: Edinburgh/Glasg Status: Offline Points: 58 |
cheers for advice. so that '210' is too big? what sort of gap should be between the driver and the inner baffle? |
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
10mm behind the drive should be fine. i.e. if driver is 100mm deep make the chamber 110mm deep from front of baffle...... this should be fine.....
mykey-
you could do the Fane from the plan thats already up and do your double baffle.
You can do what mods you want, no fuss to me. But making the chamber bigger will need a specific driver Edited by mykey- - 04 February 2013 at 1:44am |
ennayess
I made the chamber bigger to use a Turbomax driver, as i read. I wasnt sure how much bigger i needed to make it.
mykey-
Oh OK, well another way of getting round that is to open the throat up a bit and leave the chamber as is
mykey-
PM me the specs for the turbo max
levyte357-
Would be better to tell people to leave this scoop as is, and use Turbomax in COW scoop. |
mykey-
have you heard them then? Someone recently told me how good the ones Saul sold. Are they loaded with turbomax now?
mykey-
mykey-
So by taking 450 and reducing it to 425mm will give you a bigger chamber and throat without messing with anything else. This would give you the sound that most scoop lovers are looking for these days 70 litres minus driver 18'' = roughly 11 litres would leave 59 litres and a throat size of 849 Chamber and throat are close to Wattco scoop territory Edited by mykey- - 04 February 2013 at 2:02pm |
bee
pluss one the bigger throat opening will give you less cone control but more low end...
