Fane scaled up |
Page <1 10111213> |
ben 13 ![]() Registered User ![]() ![]() Joined: 31 March 2011 Location: france Status: Offline Points: 40 |
Hello Pasha
Did you try them ? How does it sound ? |
KidCreole ![]() Old Croc ![]() ![]() Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3599 |
Mykey Wattco
seb921 ![]() New Member ![]() Joined: 10 August 2015 Status: Offline Points: 1 |
Greetings people!
I am new on the forum and looking for a few advices from you people that got scoop experience ![]() I would like to know if the large chamber version (big up mickey!) could give good results with the Fane Colossus PRIME 18xs. Local sound use that driver in super scooper and is very satisfied but i would like to try to build the Fane scoop that looks easier to built. Thanks in advance and sorry for my lack of knowledge, i am still a beginer. |
SattaYard ![]() Registered User ![]() ![]() Joined: 18 September 2013 Location: Slovenia Status: Offline Points: 23 |
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8091 |
Years ago, many people reported 18XS was not very good in Scoops. PD 1851 Work well in larger chamber version, PD1852 in Smaller chamber version. I have P1851 and 1852 for sale. In UK.
Have just advertised the PD1852s on FB.
https://www.facebook.com/marketplace/item/195103023239076 Edited by levyte357- - 21 July 2023 at 9:09am |
The 1852s are unused since recone (in 2022), and 4 ohm units.
APSUS ![]() Registered User ![]() Joined: 08 May 2011 Status: Offline Points: 38 |
If the panel behind the speaker is 440mm and not 450mm, how would that sound with the 18NLW9601? The front panel is 36mm so the speaker clears the rear panel by 10mm.
Edited by APSUS - 22 September 2023 at 1:37am |
With only 10mm clearance, that voice coil will get extremely hot, at high power input, and cause power compression. That chamber will be too small, for 18NLW9601.
I've have owned that driver, and in right box, with suitable power, is top class performer. |
paulus ![]() Old Croc ![]() ![]() Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3173 |
don't do it 10mm way to small !!!!
TRENDSETTER SOUND SYSTEM
What would you recommend for clearance?
cravings ![]() Old Croc ![]() ![]() Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7425 |
someone once said a gap of at least the diameter of the vent on the back of the driver...
Page <1 10111213> |
