Fane Sovereign 12-300 |
GekoMusic94
Joined: 03 February 2010 Location: Italy Status: Offline Points: 469 |
Topic: Fane Sovereign 12-300Posted: 09 May 2015 at 10:41am |
Hi guys!
I'm going to build wo x12 loaded with two Fane Sovereign 12-300. I must go cheap so i was thinkin on going passive and i've founded these crossovers relatively cheap: http://www.audiovideoparts.com/disegni/PF206 Do you think that the Fanes will sound bad up to 2.4k? On the datasheet the graph looks ok up to that. Thanks, Giacomo
https://soundcloud.com/dj-uber
rish
Joined: 18 June 2008 Location: Durban Status: Offline Points: 547 |
Posted: 09 May 2015 at 10:50am |
Which compression driver are you going to use?
Rish
GekoMusic94
Posted: 09 May 2015 at 11:02am |
I was thinking the Ciare PU340 http://consumer.ciare.com/?altoparlanti=pu340&output=pdf
with the PR321 horn. Giacomo
