  New Posts New Posts RSS Feed - Fane Sovereign 12-300
GekoMusic94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GekoMusic94 Quote  Post ReplyReply Direct Link To This Post Topic: Fane Sovereign 12-300
    Posted: 09 May 2015 at 10:41am
Hi guys!
I'm going to build wo x12 loaded with two Fane Sovereign 12-300. I must go cheap so i was thinkin on going passive and i've founded these crossovers relatively cheap: http://www.audiovideoparts.com/disegni/PF206
Do you think that the Fanes will sound bad up to 2.4k? On the datasheet the graph looks ok up to that.
Thanks, Giacomo
https://soundcloud.com/dj-uber
rish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rish Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 10:50am
Which compression driver are you going to use?
Rish
Post Options Post Options   Thanks (0) Thanks(0)   Quote GekoMusic94 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2015 at 11:02am
I was thinking the Ciare PU340 http://consumer.ciare.com/?altoparlanti=pu340&output=pdf
with the PR321 horn.
Giacomo
