Filling old bolt pattern and drilling in a new one |
Post Reply | Page <12 |
SouthwestCNC
Personally id drill them out to 9/10mm (depending on what size plugs you make), get myself a plug cutter and with a bit of pva and plug them. Very easy to do and once flushed off look either smart or almost invisible depending what wood you cut the the plugs from.
To get centre all you need is a template and two holes marked up to reference from, easy enough, just mark up an axis through the centre of the cutout parallel to the box sides and mark the two holes using the cutout as reference or if you want the holes offset from centre, You simply need to mark the template with the angle of rotation from the centre axis and instead of marking the two holes in last step you mark the outside of the template on the driver panel instead. Edited by SouthwestCNC - 08 September 2017 at 10:50am |
love2all
Registered User Joined: 30 October 2015 Location: london Status: Offline Points: 131 |
They cut out for m6 bolts so thinking i need 8mm plug to tap in with some pva... not much of a craftsman so going to get the job outsourced but wanted to know what people thought were good options. Nickys is deffo fool proof but just wondering on how airtight it would be...
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
You can get fluted dowels, which will give better adherance, particularly if used with a polyurethane glue rather than PVA.
http://www.ebay.co.uk/itm/Assorted-Wooden-Dowels-Fluted-Pin-Wodwork-Tool-Grooved-Beech-Wood-M6-M8-M10-/121799052477?epid=1642239972&hash=item1c5bca0cbd:m:mWNypa_n96CD_m-WC4QPk1w |
love2all
That makes life easy! Another solid suggestion.
love2all
Hello - what silicone do you reccomend? Also is there any other product which one can suggest to help create a seal (no air leak)
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
Use an insert nut in the old holes
Then put a bolt in it from the otherside, inside the chamber Done
love2all
Even easier...thanks
bee
Old Croc Joined: 14 June 2011 Location: Middlesex Status: Offline Points: 4553 |
done it this way many times, that way you can swop driver back ect, I prefer lock tight to silicone.
love2all
Nice one bee
