  New Posts New Posts RSS Feed - Filling old bolt pattern and drilling in a new one
SouthwestCNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthwestCNC Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2017 at 10:37am
Personally id drill them out to 9/10mm (depending on what size plugs you make), get myself a plug cutter and with a bit of pva and plug them. Very easy to do and once flushed off look either smart or almost invisible depending what wood you cut the the plugs from.
To get centre all you need is a template and two holes marked up to reference from, easy enough, just mark up an axis through the centre of the cutout parallel to the box sides and mark the two holes using the cutout as reference or if you want the holes offset from centre, You simply need to mark the template with the angle of rotation from the centre axis and instead of marking the two holes in last step you mark the outside of the template on the driver panel instead.
Edited by SouthwestCNC - 08 September 2017 at 10:50am
love2all View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote love2all Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2017 at 11:55am
They cut out for m6 bolts so thinking i need 8mm plug to tap in with some pva... not much of a craftsman so going to get the job outsourced but wanted to know what people thought were good options. Nickys is deffo fool proof but just wondering on how airtight it would be...
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2017 at 12:00pm
You can get fluted dowels, which will give better adherance, particularly if used with a polyurethane glue rather than PVA.
http://www.ebay.co.uk/itm/Assorted-Wooden-Dowels-Fluted-Pin-Wodwork-Tool-Grooved-Beech-Wood-M6-M8-M10-/121799052477?epid=1642239972&hash=item1c5bca0cbd:m:mWNypa_n96CD_m-WC4QPk1w
Post Options Post Options   Thanks (0) Thanks(0)   Quote love2all Quote  Post ReplyReply Direct Link To This Post Posted: 08 September 2017 at 12:19pm
That makes life easy! Another solid suggestion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote love2all Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 2:09pm
Hello - what silicone do you reccomend? Also is there any other product which one can suggest to help create a seal (no air leak)
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 7:02pm
Use an insert nut in the old holes
Then put a bolt in it from the otherside, inside the chamber
Done
Post Options Post Options   Thanks (0) Thanks(0)   Quote love2all Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2017 at 7:24am
Even easier...thanks
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2017 at 9:46pm
Use t nuts that are there with a countersunk head bolt. Do them up and leave them flush
done it this way many times, that way you can swop driver back ect, I prefer lock tight to silicone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote love2all Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2017 at 8:20am
Nice one bee
