Filtering type.. |
Crazy Dane
Registered User Joined: 14 October 2010 Location: Denmark Status: Offline Points: 303 |
Posted: 13 May 2011 at 8:18am |
What do you use to high and lowpass low cabs?
Butterworth, Linkwitz Riley or Bessel? And how steap? 12, 24 or 48db/oct?
LondonTowers
Registered User Joined: 23 July 2010 Location: Colchester,Esse Status: Offline Points: 281 |
24db butterworth high pass normally low pass is a 24db l-r.. just what sounds best on my cabs..
toastyghost
24dB Butterworth to get the cab in phase across the passband on a few cabs, L-R on others, all depends on the setup.
Saturnus
Old Croc Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2025 |
The obvious answer would be Bessel filters. Those give maximally flat group delay, ie. maximally linear phase response. This is important in active filters Butterworth filters are maximally flat magnitude filter which is important in passive filters. |
