  New Posts New Posts RSS Feed - Finally, Nearly Finished my 186's (Pics)
_banksy_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Topic: Finally, Nearly Finished my 186's (Pics)
    Posted: 26 March 2010 at 8:05pm
Well, nearly there!
BreakBeat!
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2010 at 11:41pm
Looks nice to me!
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2010 at 8:58am
good work
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2010 at 1:42pm
I hope I am wrong but that looks like poplar or similar ply, please tell me I am wrong Cry
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2010 at 8:29pm
Yes it is poplar core, It is awful stuff, regrettably I didn't do my research on plywood before building the cabs, I remember reading to use birch ply and for it to be over 12 laminate, well I stumbled across this ply and it was 12 laminate and looked to be good quality on the racks at the timber yeard, got it to the workshop and cut all my pieces to size then some of them warped, it really pissed me off because I am actually building them for my school project and it was too late to start again.
However it is actually ok now it is all fixed together as one rigid structure, and now they are sealed with Tuff Cab paint they are really nice, very rigid and strong / straight.
Now I have learned my lesson, the next set I build will be made from birch ply!
BreakBeat!
Nitz V1505 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2010 at 5:53am
A good prototype then!!!!! some people mock up in mdf b4 shelling out on birch ply so no harm done.
Is it me or can someone see a subliminal message appearing about evey minute for a split second under the emotion icons and beside the post reply button? Or is it just me?
cnc123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnc123 Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2010 at 2:43pm
poplar core be nice and light then (good)
just watch the edges
a bit soft there so splinters easier
dewsons do a popular, with birch on the faces
has to be ordered, and expensive but light
by the way birch warps as well, depend on the weather and how its stored (Flat)
it takes a least a week to go flat to put on a vacuum bed on cnc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2010 at 7:57pm
 I saw that message again,it says loading!!!!!
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2010 at 9:12pm
Wisa Twin is another Birch FACED option.
Jewsons (ugh) will do it for £35 plus VAT if you ask, not much less than BB, tenner ish, but those tenners mount up on twenty sheets or so.
15mm BB is a load cheaper than 18mm, LABS are made from 15mm IIRC?
Even Travis quoted me £38ish inc VAT for it.
It just is.
galaxydiscos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote galaxydiscos Quote  Post ReplyReply Direct Link To This Post Posted: 02 April 2010 at 5:05pm
nice build
i-stack-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote i-stack-10 Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2010 at 11:28pm
THEY r look good i want 2 build some but i cant find any plans with anglesCry where did u get ur from
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2010 at 9:06pm
hi banksy.
below the baffle there should only be one brace per fold for two folds and then two on the bottom. thats what the plan says anyway. Wink
Edited by RUS - 13 November 2010 at 9:14pm
