firs pics of my rig build |
Page <1234> |
Ohmen Audio
Joined: 21 May 2011 Location: Bristol Status: Offline Points: 34 |
Posted: 10 January 2012 at 12:03pm |
nice work as well i love 1850's can never have enough of em :)
joints and joinery
MessTek
Joined: 27 January 2012 Location: andover hants Status: Offline Points: 67 |
Posted: 31 January 2012 at 7:59am |
Ive just sold my old rig and was planning on making 8 1850's like yourself, how much has this project cost you in terms of ply?? how many sheets is it taking you per bin??
thanks
Mess-tek
Edd Jordan
Joined: 10 January 2008 Location: United Kingdom Status: Offline Points: 1364 |
Posted: 31 January 2012 at 10:33am |
More build pics!!!
AUDIO HABIT
Joined: 15 June 2009 Location: Manchester Status: Offline Points: 3383 |
Posted: 31 January 2012 at 8:38pm |
Yeah hows the xtro build comming on ...top job by the way
phildat
Joined: 29 January 2009 Location: manchester Status: Offline Points: 1115 |
Posted: 31 January 2012 at 8:57pm |
let us know when you out and about..would like to hear this monster!!
Its just a ride.
despoiler
Joined: 28 August 2009 Location: nr manchester Status: Offline Points: 25 |
Posted: 01 February 2012 at 9:13pm |
My friend and I made the template for the xtros yesterday, the 10mm scrap ply I used wasn't exactly ideal but a bit of glue worked into the edges on the corners and any weak spots to harden it seems to have sorted it out. We will be using it for making the cab sides on our next workday.
As for the amount of ply needed for the 1850's, I think it worked out to less than 6 or 7 sheets for 8 cabs, it's a while since I bought it and I cant remember for sure, with some creative cutting it may even be managed with 5-6 sheets. I bought marine ply as beech was not available locally. I already have the tops,bottoms,backs & sides for the xtros but still need to get the internal horn sections cut to size now I have the correct measurements to fit my plan, 25 seperate sections is gonna be a lot of plane work Template and tools used. And my work bench You can also see some of the 1850 template behind. Not a great job but it worked and I learned a lot making it so the xtro template was a lot easier. I'll add some more pics next week, hopefully.. Edited by despoiler - 03 February 2012 at 5:53pm |
godge
Joined: 07 July 2010 Location: Gloucestershire Status: Offline Points: 598 |
Posted: 01 February 2012 at 9:27pm |
look forward to seeing it all together, sounds like it will be a beast
despoiler
Posted: 19 February 2012 at 9:18pm |
I would be very grateful if those of you who have mentioned having an xtro/1850 rig would post your delay settings for me so I have a somewhere to start without having to tax my own brain too much working it out. I have the settings for a xtro/punisher rig but they wont help much as the punisher horn looks much longer than the 1850.
lukehaze1
Posted: 22 February 2012 at 12:53pm |
nice build.
i have the same just need to load them when you loaded them what bolts did you use and or did you screw them in woth t nuts? |
UpComingSound
Joined: 21 June 2006 Location: United States Status: Offline Points: 394 |
Posted: 09 April 2012 at 11:53pm |
will the B&C tbx100 work ok in these cabinets?
despoiler
Posted: 26 November 2012 at 4:54pm |
Yes we used Tee-Nuts and M8 pan head screws, it's worth buying Allen key bolts if you can find some long enough as getting to them when fitting can be a struggle, you need a minimum of 40mm long, I found 45mm the best size.
Work has been progressing on my xtros and I shall add some more pictures very soon, I almost have everything ready to start assembling the 1st pair.
b grade
Joined: 05 October 2012 Location: Portland OR USA Status: Offline Points: 1333 |
Posted: 26 November 2012 at 5:12pm |
Nice build. I am building 4 1850s. I am assembling the 4th some time this week.
Page <1234> |
