First DIY build - MTH-30 |
Post Reply | Page <12345> |
jamwa
Young Croc Joined: 10 February 2009 Location: Southwest Status: Offline Points: 1060 |
well I have found the driver that Danley uses for his cabs
Faital pro HP1020
700w RMS
1400 Program
dont suppose someone fancies doing a sim with the MTH-30 if they are feeling in a good mood...
_djk_
"well I have found the driver that Danley uses for his cabs"
The TH-Mini pictured at the Danley site uses this driver: http://www.parts-express.com/pdf/294-665.pdf The TH-812 and TH-412 look to use a Faital Pro driver, but it may be custom as Danley rates it at 1KW per driver and there is no 12" driver rated that high at the Faital Pro site. The difference in weight is about +7lbs, and -0.6875mm in x-max for the B&C, but it is $100 less (in the USA, $180 vs $280). http://www.faitalpro.com/products/schede/hps.php?id=201050110 |
djk
jamwa
ah well thought I might have got somewhere.
okay how would the B&C Driver work in the MTH-30
huhts
Registered User Joined: 23 December 2009 Location: Helsinki Status: Offline Points: 29 |
if someone is using rhino3d I have a model of mth-30. I can try to plot it as a 2d pdf with cut sheet when I'm back to office with autocad.
_djk_
"okay how would the B&C Driver work in the MTH-30"
Hmm, I dropped both the Faital and the B&C into my AkAbak TH design, and the RCF LF12G301, PD 12SB30 , RCF L12P540, and the JBL 2206 all look better. |
djk
colint
Old Croc Joined: 06 October 2007 Location: United Kingdom Status: Offline Points: 5227 |
Funny that? I was thinking about the 2206 in this cab yesterday, I know the PD driver is very cheep for what is is but the jbl has better power handling with the extra 200 watts & easier to source second hand.
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
Hi _djk_ how did you take care of the driver volume that protrude into the last 2 horn segment? cheers, bitzo |
_djk_
I usually design with about 100~150cm^2 extra at the mouth. This gives a small bump in the simulated response right before cut-off.
djk
bitzo
uhummm a different way from mine... I calculated the volume and how is took place in the segment regarding baffle angle. a bit tricky but it's pretty close to measurement.
_djk_
I'm not sure if it's the cross-sectional area, or the volume that's important. I suspect it's the area of the mouth being blocked, not the volume being displaced. In any event, a little extra area dosn't seem to hurt anything.
djk
asaa00
Registered User Joined: 28 January 2008 Location: Los Angeles Status: Offline Points: 358 |
Hey! Id love the sketchup plans if you ever found them! (your PM is full) asaa@ggsoundsystem.com Thanks!! Edited by asaa00 - 19 August 2010 at 8:51pm |
hey_homes
Registered User Joined: 13 November 2009 Status: Offline Points: 34 |
Guys, with regard to the angle at the end of the 340 mil front panel, how do you work it out? Is it simply a case of measuring it - like with a protractor - or am I missing something? Edited by hey_homes - 06 September 2010 at 9:45am |
