First Rig - "Expander" Plans |
Zik
Registered User Joined: 20 June 2017 Status: Offline Points: 20 |
Posted: 20 June 2017 at 11:59am |
Hi All!
I've been meaning to put together a system for a while now and just came into enough money to do so. Aims are:
It looks like the plans found here: http://www.forum.poweraudio.ro/viewtopic.php?f=92&t=9947 are pretty perfect. This being my first build I've got some questions that I'd like answers to before I go pulling the trigger on buying drivers etc! In no particular order: Driving the system:
Building the system
Thanks for reading through that mountain of questions - will put a project thread up as soon as things get under way! Cheers Z
Zik
Can't work out how to edit posts so for completeness the drivers the plans call for are linked below:
P Audio E10-200S http://www.bluearan.co.uk/index.php?id=PAUE10200S&browsemode=manufacturer P Audio PHT408 http://www.bluearan.co.uk/index.php?id=PAUPHT408&browsemode=manufacturer P Audio E-18ELF (Substituted for the FL-18ELF) http://www.bluearan.co.uk/index.php?id=PAUE18ELF&browsemode=manufacturer
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
looks neat, reminds me of the outline kanguro system.
Just throwing another option: |
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 884 |
For your future assistance click on 'Post Options' (top right of the article) and select the bottom option 'Edit Post' |
If your vaccinations were mandatory and nobody in your class had measles,
then you know that you're not a Millenial kid.</f |
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
if you don't mid paying a bit extra for quality drivers then maybe search the forum for tony wilkes Q18 compact bass bin and Q28 tops these use top of the range BMS drivers ,sadly tony passed away but forum member bee has the plans available for a small donation to British heart foundation
GOD TOLD ME TO DO IT !!!!!
