  New Posts New Posts RSS Feed - Folded Horn for a Mid? - High SPL's
owentec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote owentec Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2006 at 3:04pm
Anyway, your horn.... not much high frequency will come out. Some low frequency might come out, depending on how big you make the horn exit, and how long you make it.
Edited by owentec - 10 December 2006 at 3:05pm
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2006 at 1:13pm
looks like it might be tricky to stack though, and wehat you going top make it out of, all those wobbly lines. The worlds first levitating jelly horn mid?
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2007 at 4:07pm
This will work up to 200Hz.
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 20 April 2007 at 12:52pm
The horn you have designed has some similarities with Bill Fitzmaurices DR horns, however it must have totally rounded bends to get up to the midrange, his DRs go up to 2kHz before they roll off. Fraid he has beaten you to it, yes longer horn = higher efficiency though, thats why he does it, time domain problems are likely to occur but subjectively how much difference do they make to the sound? Ask a DR builder.
Stu
All you need to know is:
My acts:
