  New Posts New Posts RSS Feed - 🚨Jah tubbys 4way pre repair
Youngculture89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Topic: 🚨Jah tubbys 4way pre repair
    Posted: 04 April 2019 at 8:07pm
Just recently bought a jah tubbys custom 4way POSTED ("NEW") ...
when it arrived first thing i did was plug in power, there right away i noticed all the led light where lit full peak range on the highs and mids $ and halfways on the bass sections.. And nothing was yet plugged in except power... What came to tought is maybe is normal tuing so i continued to set up the pre to my speakers. And turntable full range method..  Once "on" the loudest high pitch screechin peaking feedback noise occured.. And this is with volume all the way down! No music at all just feedback screech.. Then tried it 4way to the sound and same thing.. Supposedly being "new preamp" i thought i was doing somethong wrong , so after reaching out to a few bredrin with a jts pre aswell for advice.. None knew what was causing that noise. Although this preamp was not bought from tubbys direct i did link him for repair and service info but is laaging on responce...  Asking anyone with the knowledge of the preamp what this issue might be. .....get a refund? Send for repair?? Easy fix???
Edited by Youngculture89 - 04 April 2019 at 8:33pm
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 8:30pm
This may sound daft
Do you know if this model is suitable for 110v used in the USA?
Or is it a euro 220v one?
If so, are you using a step up converter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 8:32pm
Bless bro.. Yes 110 volt has a sticker right next to the power input saying so
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 9:01pm
* Edit *
Well i'm a tit
Edited by spongebob - 04 April 2019 at 9:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 9:06pm
here in usa is 110-120v have not used 240 power
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 9:37pm
Whoops, my bad. As you were gents!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 9:45pm
As you can see by the labels its rated 110-120.. Yet when i llok into the plug socket inside it says... 10a 250vac..??????pic
Edited by Youngculture89 - 04 April 2019 at 10:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 10:15pm
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 10:32pm
As its been send from uk it might be worth doing some simple testing before sending it back.. Do you have a multi-meter? And know how to use one? If so take lid off, check the main transformer.. what ac voltage is coming out the transformer? Should be approx +20v (ac) and -20v (ac) After the transformer there will be a bridge rectifier, smoothing caps and 2 voltage regulators, after this point there will be 3 voltage rails, probably 0v (ground) +15v (dc) and -15v (dc)... though could be say, +-12 to +-17..  check you have these voltages.. if so the mains voltage and psu are fine and its something more complicated..
My guess is the power supply is the problem..
Reverence Sound system
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 10:37pm
ok gonna link a bredrin to come test that.. Dont wanna plugg into 240v and blow it up
Post Options Post Options   Thanks (0) Thanks(0)   Quote I-shen Soundboy Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 10:47pm
That's just the maximum current and voltage rating for the plug socket.
Follow the rating label on the box:
Stick to 110/120v
Edited by I-shen Soundboy - 04 April 2019 at 10:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Youngculture89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 April 2019 at 10:49pm
Stick to 110/120v
Yes bro had that in thought..give thanks
