powersoft k10 no sound/dsp error |
Page 12> |
gimmebass
Joined: 03 May 2022 Location: netherlands Status: Offline Points: 34 |
Topic: powersoft k10 no sound/dsp errorPosted: 30 November 2025 at 6:48am |
hello all,
i bought 2 broken k10's 1 had a the left channel that didn't work and a screen that was only lid. switching the front panel solved the problem, channel was on mute. contacts where heavely corroded en components where falling of. that i cannot fix so thats being repaired by a professional. now the next amp has everything working but started with a 'sharc error' that was solved with armonia, after connecting the firmware was updated and the error was gone. al the settings where set on factory settings. my hands where itching to test my recently bought 13x mach ms118 cabs.\ so i hooked 8 of them to the amp, the bottom led's lid up after applying signal and bass came out. then the bass stopped, whent back on for 3 min, then off.....take an other xlr cable to rule that out. when the bass stopped the bottom leds where out, so no signal present, checkt the xta en yes it's giving signal. took the amp inside for a closer look, discharged the capaciters en started checking. after my experience with the first amp i checked the front panel for corrosion(ok). took the amp board out and checked the link/stereo switch (ok). checked the bandkabels(ok).took the dsp board out to clean the contacts but they looked in perfect condition. put everythinh back together and hooked it back on my laptop,connecting was nog problem, all the basic settings and data was in real live and worked, dsp settings opend for a brief moment and then it flipt to (initalizing) en after a min it flipped over to a workspace that worked??opened somethin en that it when't back to (initializing connection) i put in a xlr bluetooth audio device and when the dsp is working the bottom led's lid up. they go out when it's(initializing connection) i'm thinking powersuply, bad contact?something like that. does this familiar to somebody?? |
16x mhb 46, mach slingshot ms1262
Elektro Cat
Joined: 23 January 2019 Location: Germany Status: Offline Points: 12 |
Posted: 03 December 2025 at 12:06pm |
Hello, there is an SMD resistor on the DSP board that is corroding after the conformal coating has dissolved after a few years.. I had the same problem with my k10 DSP, and replacing the resistor got the DSP working again. The resistor is located directly to the right of TP2 on the top side. Hope this helps.
gimmebass
Posted: 03 December 2025 at 12:43pm |
wow that one is easy to miss, just checked my board after cleaning with a brush.
indeed corroded, the one just under the red connector is also a bit corroded. i will have them replaced! thank for your tip!! much apreciated!!
gimmebass
Posted: 03 December 2025 at 3:59pm |
btw do you know the resistance of the component?in case its broken and can't be measured.
simonp1100
Joined: 01 September 2008 Location: Bristol Status: Offline Points: 1150 |
Posted: 08 December 2025 at 1:21pm |
Hi,
I have the same problem. The resistor in the middle of the capacitor and the connector is a 470R but cannot read or make out the other resistor (horizontal to the board edge) it reads 01 and sure the third digit is 0 (so 010) but cannot read the last digit and mine is also open circuit. Does anyone know or has a board they could measure or a circuit diagram ???
Elektro Cat
Posted: 08 December 2025 at 1:24pm |
One resistor is 470r and the other one is 01C/10k
gimmebass
Posted: 08 December 2025 at 1:45pm |
thnx guys! i will post my findings.there's not much information on the web.
this helps diy people a lot!
Sypa
Joined: 21 February 2013 Location: Croatia Status: Offline Points: 953 |
Posted: 09 December 2025 at 10:01pm |
Hi I just put a new LCD on a k10 and still no letters on the screen . What did you do with the display board got a new one or ? Do you have any spare , it also seems some resistors are gone but I can't find no one to tackle that issue.
pic sorry on mobile not sure how to embed
gimmebass
Posted: 10 December 2025 at 6:53am |
Your problem lies with the resisters not the screen.
Mine is stil at the repair shop, so will get back to you when it's back.
Sypa
Posted: 10 December 2025 at 8:53am |
Yeah i found that out when i put in the new screen
gimmebass
Posted: 18 December 2025 at 6:52am |
hi,
al the problems are solved, dsp works perfect and the screen of the other is also working. cleaned both amps, washed the filters and replaced the led's that where broken. also took the powersuply connector out en made a permanent cable connection. thanks all for the help!!!
dnbpc
Joined: 18 March 2010 Location: Manchester Status: Offline Points: 398 |
Posted: 07 January 2026 at 3:27pm |
Do you have a link to the replacement screen you purchased? I have a k10 where the screen has a lot dead pixels but not been able to locate the replacement LCD screen part.
Pick & Mix Soundsystem
Page 12> |
