MT121 questions |
SonicXtasy
Joined: 02 February 2008 Location: United States Status: Offline Points: 526 |
Topic: MT121 questionsPosted: 08 August 2008 at 12:58am |
Hey guys, finally revising my system and need some opinions. I will shortly have 2 X1's (adding 2 more later) and four 2 X 15" reflex kick bins. I have a set of P-Audio SN12B's and will be getting another set soon. I also have 4 Selenium D3300Ti DPD 2" exit comps with Community 60 X 40 horns (probably replace horns with smaller units). I assume my Selenium comps will work in the design. Will 2 pair keep up with the 4 X1's and 4 kicks? How low will they play and what is the recommended xover freq. Lastly, how well do they sound? will they take your head off at close range? I am also considering the the SMT212 (coaxial mounting the horn between the 12's) which is not actually horn loaded. How would the 2 compare in sound quality and output? The MT122 is just too big for what I want to lug aroung as tops. Any advice would be great.
The member formally known as vwbidder.
SonicXtasy
Posted: 08 August 2008 at 1:03am |
Forgot, the other reason I am considering only 1 12 per cab designs is because the current 2 amp choices I have for the mids are only 4 ohms stable, a Crown Powerbase 3 or a Samson S2000. I might be able to trade some stuff to a friend for his QSC PLX2402 which would run 2 ohm.......and match my 2 PLX3402's nicely |
