  New Posts New Posts RSS Feed - Best Plan for P. Audio SD-15
AgentLovely View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentLovely Quote  Post ReplyReply Direct Link To This Post Topic: Best Plan for P. Audio SD-15
    Posted: 22 January 2009 at 6:49pm
Ive looked all over and found nothing referencing this subwoofer. Any help would be appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentLovely Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2009 at 3:25pm
Here are the specs if that helps.
SPECIFICATIONS
Nominal Basket Diameter
15" / 380mm
Impedance
8 ohms
RMS Power Rating
600 Watts
Program Power  1200 Watts
Frequency Response
40Hz - 2.2kHz
Sensitivity (1W/1m)
97dB
Voice Coil Diameter
4.5" / 114.3mm
Voice Coil Material Anodized CCAW+fiberglass
Terminal Type Gold Plated Push
Bobbin Material Fiberglass
Basket Cast Aluminum
Cone Material Paper
Surround Material Treated Cloth
Magnet Material Ferrite
Net Weight 15 kg. / 33 lbs.
MOUNTING INFORMATION
Bolt Circle Diameter 14.57" / 370mm
No. Of Mounting Holes 8
THIELE-SMALL PARAMETERS
Resonant Frequency (fs) 41 Hz
Impedance (Re) 5.1 ohms
Coil Inductance (Le) 1.95mH
Mechanical Q (Qms) 7.33
Electromagnetic Q (Qes) .27
Total Q (Qts) .26
Compliance Equivalent Vol. (Vas) 121.7 Liters/4.79cu. ft.
Voice Coil Overhang (Xmax) 5.0mm
BL Factor (BL) 24.7
Surface Area of Cone (Sd) .085m2
Reference Efficiency 2.96%
Glenn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glenn Quote  Post ReplyReply Direct Link To This Post Posted: 01 February 2009 at 10:54am
Staiper Microscoop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentLovely Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 6:12pm
Ive looked in the scoops forum and went to a MSN website with staipers plans but could not find that scoop? Do you know the location to find this plan? Looks interesting! Do you use this scoop personally?
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 6:33pm
.. May I help you Wink:
  PLANS
  Parts - CUT LIST
.. I'll check what simulation "say" .. when I return home.
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 7:38pm
good to knows! could you post the sim data input? I'm pretty curious :D
(and lazy)
Edited by bitzo - 02 February 2009 at 7:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 02 February 2009 at 9:16pm
bitzo Smile
HR simulation looks far from nice ..but in reality works like charm Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentLovely Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2009 at 2:01am
The P. Audio SD-15 basket size is around 190 millimeters...I bet the back end will not fit into this design :(
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2009 at 4:20pm
Don't forget to set path difference to roughly 9.5 cm.
Best regards,
Teun.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentLovely Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2009 at 2:47am
Decided to go with the BR115. Here are the 2 boxes I built!
This is my first time building any boxes. Tested it outside my doors with a TAPCO 2500 power amp. 30 seconds after I turned it up 6 people walked outside with angry looks on there faces. <3
Post Options Post Options   Thanks (0) Thanks(0)   Quote AgentLovely Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2009 at 11:01pm
staiper do you have a alternate link for the microscoop plans and cutlist?
