X15 setup |
Fats
Topic: X15 setupPosted: 23 October 2005 at 4:16pm |
Am slightly struggling to understand difference between the two proposed setups for the X15. Can anyone using the VX2,the SD 1.5" etc setup enlighten me as to its advantages? Also if anyone's using the VX2 do you know the info on its power/peak as it is not up on Pro-audio parts.. - on the subject what is the Paudio PC 5038 anyway? I cant find it anywhere on their website... Hmm. Help appreciated. |
angus
Joined: 10 August 2005 Location: TW, Kent, UK Status: Offline Points: 516 |
Posted: 24 October 2005 at 9:53am |
I am currently trying to decide between the two setups myself and short
of actually listening to them side by side, I think it comes down to a
question of practicality. I.e. the smaller non-neo magnet 1" comp
driver (450) will sound nice when the cab is run passive and can also
be tweaked a bit when run active to get a nice sound but it may not
keep up with the rest of the system. With a 1.5" or 2" driver on a 2"
horn like the 3223 you have that ability to go louder and further later
on when you run active maybe.
The downside is that some people say that the larger diaphragm comp drivers can sound harsh at the top end. Again it comes down to personal choice and listening to them (so I've been told many times!). Just wish I could get somewhere and listen to them in the X15 cabinet ![]() Oh, and the 5038 is a horn adaptor, 5th from bottom on this page. cheers, angus P.S. Martin (TimberMG) said in a post recently that he would definitely go with the larger comp driver second time around - is this correct Martin? (My 2 x15s are the start of my rig as they are very very versatile. I suppose in the long run, once I have added some kick bins and/or subs to them, then I would replace the x15s with some nice modular horn mids and tops and then use the x15s as monitors or in fill. I currently have no plans for monitors when using the x15s and imagine it will be the muddy, back-of-the-box sound that gets used as the monitor .
Point being, big comp drivers can be harsh when used in monitor
applications - cue whinging DJs, me included. But can't you just cut
this 'harshness' out with EQ???) |
Timber_MG
Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Posted: 24 October 2005 at 12:02pm |
Yup. Though it needn't be a P.Audio comp, there is more to what is generally mentioned on this forum.
I find the post 8kHz ringing on 3/4" diaphragm compression drivers to be OK, assuming using a decent horn AND setup (watch what happens of axis). I would use a larger waveguide/horn with the driver with a 15, for singles likely the 3223 as indicated in the plans if it were an off the shelf jobbie. I would also drop the shelf port and use two tri-angles to shave off some of the box's height (allowing it to rest upright on say a car-seat). It is not a compact box by any stretch of the imagination. The BM-D750 (740 is a 1.5" version) is reasonably heavy and the 450 isn't exctly light by modern standards either, but it shouldn't mind a 1.2kHz cross to a 15". ft it is to be passive (more practical) I would check out the crossover options (do PAP do something for the 2"/1.5" setups?) |
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8800 |
Posted: 28 October 2005 at 1:58pm |
I've been playing with SMAART tonight on my X15 which is standard to the Option 1 parts apart from using a PH2513 instead. I was crossing over using 12db LR filters at 1.6k lowpass and 2.2k hipass. Once i'd got it on the screen i tweaked it until i came up with the flattest plot without using EQ. Ended up with 1.6k lowpass and 2.3k hipass both using 24db LR filters. There is still a dip in the response at 2k but no amount of tweaking could bring it up without EQ. Must be the comp driver and horn characteristics. I then used EQ to do the rest -4db BP at 4.3k with Q=5 to remove a hump in the plot, right where it can make hihats and stuff seem really hard. +8.5db hi-shelf 12db slope at 13k to bring out the sparkle a bit. They were surprisingly flat all the way down with a little hump near 50hz. I'm not sure if the PLX have the ramped filter like the RMX's but this could explain that Here's the final plot once i'd levelled the amps out and applied EQ
Edited by norty303 - 29 October 2005 at 9:33am |
