  New Posts New Posts RSS Feed - need help with csub
need help with csub
robotnation View Drop Down
Member Banned!
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotnation Quote  Post ReplyReply Direct Link To This Post Topic: need help with csub
    Posted: 19 January 2006 at 10:30pm
alright imgetting ready to build myself a csub, and i need to know a couple of things.  first of all... does anyone knwo the specifics of the removable pannel and batten?  I am curious if someone has a drawing of what the back looks like and also if they could tell me what on earth a batten is and what type of wood i need to build one. second... i am wondering how the csub affects phase and if so how can i prevent that from hurting my sound?  what do i need to fix a problem liek that inexpensively?
PS i need to build this thing by march the 4th, so im in a bit of a hurry and any information on this would be apreciated greatly.
Member Banned!
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotnation Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2006 at 10:39pm
i forgot to mention i have this crossover http://www.behringer.com/CX3400/index.cfm?lang=ENG
does that delay thing they talk about acount for phase?
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 4:36am
regarding phasing, when you are running the gear twiddle the delay knob
until the sound is most "together" around the crossover point. you can try
and science it but your ear is probably more accurate.
batten is just normal timber strip, you know, just planed wood. it is
available in large enough packs from most diy shops to do a few cabs. i
am using a lot of 18 x 18mm batten at the moment as it is the same size
as the ply thickness, can make for a nice visually pleasing finish.
in terms of the removable panel just keep the following in mind and you
won't go wrong. you need a hole big enough to get the driver in and you
need material on the other side of the panel to bolt it to, think door
frame. happy building.
james.
mardy hippy.
Member Banned!
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotnation Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 10:28am
Thanks for the info, i just need one last little bit of advice.... how should i connect teh speaker to the wood so that its easily removable?  I used bolts washers and locking nuts and tightened them well, but i discovered that its the most frustrating theing ever to fit a ratchet inside a tight speaker housing once its all closed and sealed.  What would you suggest i use to connect the speaker to the cabinet so that its removable?  This part is really optional, but id like to be able to change drivers without building a new housing in case i ever decide to upgrade this thing (or in case i realized i messed up the housing.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 12:53pm
what you need to use here is one of the two varieties of captive nut for
timber. the most commonly available is called a t-nut and for an m6
fatening you drill out to 8mm and then either hammer in (nasty) or use a
bolt and washer on the other side to 'draw' the spikes of the nut into the
wood (nice).
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=12749&ts=7928 6
the second type (which i use exclusively as they can't fall out) is the screw
in m6 nut insert.
http://www.screwfix.com/app/sfd/cat/pro.jsp?id=28157&ts=7928 6
james.
mardy hippy.
Member Banned!
Post Options Post Options   Thanks (0) Thanks(0)   Quote robotnation Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 2:35pm
Alright, i am gonna buy 8 of the screw in nuts (maybe more for my removable panel too), but its also not very specific what type of bolt connects to the nut inserts.  Do you know exact thread per inch and diameter i need? (oh yea btw the speaker i am using is the rcf l18 p300.)
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 2:39pm
Don't know if it's differentin the States but over here the M6 (or M5 or M4, etc) is the size of the bolt, so you'd use M6 bolts for an M6 insert.
Jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbo Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2006 at 2:59pm
I use the "T-nuts" that James mentioned.  They are readly available at most hardware or lumber stores.  If you can find a discount bolt and screw company they're much cheaper.
I also recommend using "Allen head" bolts (also known as "hex key").  You'll find (in US) that 12" and larger drivers take a 1/4 x 20.
These are what I'm talking about and not a horrible price.
  http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&P artnumber=260-778
Look around on the site.  They offer some pretty good stuff.
Jim
