d&b Audio Q1 - but not |
Page 12> |
Louder than loud
Joined: 13 May 2010 Location: Guildford Status: Offline Points: 2377 |
Topic: d&b Audio Q1 - but notPosted: 11 September 2010 at 6:27am |
A friend of mine is looking for some sort of small line array system he could build himself, i've showed him some Q1 and he loves the size....
So are there any plans around for a box like Q1 ? Thanks :)
ceharden
Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11851 |
Posted: 11 September 2010 at 11:56am |
If you can find a waveguide which produces a similar wavefront then you can build a similar box. However I think you'll find there aren't any on the market.
MarjanM
Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7845 |
Posted: 11 September 2010 at 2:23pm |
If he likes to buy some copy's of it pm me.
Ben_Lawrance
Joined: 12 January 2006 Location: Brighton Status: Offline Points: 919 |
Posted: 11 September 2010 at 4:09pm |
Only the other week, i took a Q1 apart (to fix it) and while i was inside it, i took a good look about to see if it was copyable. The woodwork seems easy enough if you have the expertise and tools etc, but as Chris said, the waveguide is the importnat bit.
Unless you have a factory, and are able to produce a clone mould, then forget it.
Also, getting hold of the correct drivers will be the next task. Then a D12 to drive it with blah blah blah.
Anyway. isn't this a DIY forum? Tell him to get his pencil out, and design his own!
MarjanM
Posted: 11 September 2010 at 4:27pm |
Well i am not so convinced that the DB dsp settings can not be made. That box is 2 way and with a Smaart or some similar program you can get it flat fairly easy. So D12 amps are not that essential.
Did you make any picture of the inside to see what drivers are inside? |
MarjanM
Posted: 11 September 2010 at 4:28pm |
And Q1 is not a true line array box anyway.
MarjanM
Posted: 11 September 2010 at 4:31pm |
MarjanM
Posted: 11 September 2010 at 4:36pm |
Nachural
Joined: 15 April 2009 Location: West Midlands Status: Offline Points: 1259 |
Posted: 12 September 2010 at 12:00am |
Looks really good Marjan, but can we see the front view of the completed cab, without grill.
MarjanM
Posted: 12 September 2010 at 1:00am |
Louder than loud
Posted: 12 September 2010 at 2:18am |
Nice
ceharden
Posted: 12 September 2010 at 11:48am |
That's not the same waveguide though is it. The D&B one uses quite a clever little trick by bending the first section in order to equalise the path length and produce a flat wavefront. Still not perfect but allows it to function as a line array to some extent. A conventional straight diffraction slot horn will not allow the cabinets to array as well.
Page 12> |
