ply wood |
Page 12> |
mouse man
Joined: 11 July 2011 Location: letchwerth Status: Offline Points: 7 |
Topic: ply woodPosted: 12 July 2011 at 3:42pm |
what would u say is the best budget ply to build 1850s from?
Pirlo
Joined: 25 February 2010 Location: Germany Status: Offline Points: 244 |
Posted: 12 July 2011 at 3:55pm |
Use the best, or die like the rest
-> 18mm-bi(r)ch-ply, nothing else - my opinion! |
Who the fu&k is Mr. Phanton, and why he has so much power!?
hmaudio
Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3852 |
Posted: 12 July 2011 at 4:01pm |
for good ply your looking at 45/55quid a sheet from b&q and that does get you some free cuts too but they also do exterior ply at 30/35quid a sheet
tbh if your not throwing them about alot i.e on tour yout gonna be fine with the exterior ply but if you plan on these cabs being used on the road i would go for the birch ply from b&q
This account is used by 2 people. |
mouse man
Posted: 12 July 2011 at 5:03pm |
yeh i was going to use birch 13 lam but didnt know if there was a slightly cheaper allternative
hmaudio
Posted: 12 July 2011 at 5:07pm |
well theres around 20quid difference per sheet so its not that much, for 2 1850s you will need 3 and a half sheets
biotec
Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2932 |
Posted: 12 July 2011 at 5:14pm |
B&Q is the overpriced alternative for people who do not live near a decent plywood importer. You should be able to get it for less than £40 a sheet anywhere in SE England.
Edited by biotec - 12 July 2011 at 5:14pm |
mouse man
Posted: 12 July 2011 at 5:22pm |
£51.06 A SHEET OR 10 SHEETS FOR £450 IS THE BEST I GOT OFFEREDED
smoore
Joined: 30 March 2011 Location: N.Devon Status: Offline Points: 966 |
Posted: 12 July 2011 at 6:20pm |
Most people i've spoken to about budget builds (I never have money) say unless your building a proffessional rig to cater for 100's then its not worth it. I only have a small stack of 4 bins and some mids/midtops so just used exterior ply and varnished it. Seems to have held up a few months so far
djeddie
Joined: 26 April 2004 Location: Bristol Status: Offline Points: 4125 |
Posted: 12 July 2011 at 9:38pm |
Today I had to cut up three sheets of exterior ply that came from B&Q (to use for shuttering around a patio and other garden features) and gotta say I wouldn't like to build cabs from it! More voids and loose knots than you can shake a stick at!
Go for the birch! Just find a Timber supplier in your local area. |
The Builder
Joined: 03 January 2010 Status: Offline Points: 3107 |
Posted: 12 July 2011 at 10:40pm |
Used WBP recently for some cabs. It's OK, but to be honest the voids get awkward with angles etc.
Jewsons do Wisa Twin. Birch outers, soft inners, very eco friendly. £33 plus VAt if you ask nicely.
It is also quite light and has very few voids.
Big Jewsons have sawmills too.
It just is.
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 13 July 2011 at 12:22am |
I buy Birch Ply by the crate (22 sheets) and I get it for £31.00 per sheet.
mikey bear
Joined: 29 October 2007 Status: Offline Points: 2379 |
Posted: 13 July 2011 at 12:39am |
which is fine unless the saw at your nearest b&q is anything like my local...manned by stubborn idiots and not correctly calibrated, ie. cuts will differ as much as +-3mm from top to bottom. The best thing I ever did was buying a festool and making all the cuts myself. I used to work as a scenic chippy building sets for theatre. We would use very cheap ply, like that mentioned previously, as it would only by needed for 3/4 weeks at a time. The quality was so poor you could make it warp just from looking at it! I would also regularly cut through thin pieces of metal found within the laminates. Another problem was screwing into the endgrain because of the large amopunt of voids. Would never consider using it for speaker cabinets. Birch or MDF. |
Page 12> |
