Subliminal Audio |
Page 123> |
| Author | ||||
Subliminal
Joined: 25 February 2012 Location: Bath/Bristol Status: Offline Points: 284 |
Topic: Subliminal AudioPosted: 27 February 2012 at 1:27pm |
Here's our new system.
![]() 4 EAW KF850 8 NCA VSB218 Old system. 4 USB2, 2 ASS BS500 and 2 ASS MX350. ![]() Edited by Subliminal - 15 April 2013 at 11:15pm |
Tom Tapey
Joined: 27 May 2005 Location: United Kingdom Status: Offline Points: 293 |
Posted: 27 February 2012 at 7:26pm |
You should be aiming for a two box system chaps, i would say get two more USB 2's and some mid top boxes that go down to around 150hz, the lower the better.
What settings are you using at the moment??
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7797 |
Posted: 27 February 2012 at 8:05pm |
what brings you to this conclusion? Might be simpler, but i see no wrong in what they have. Like the TMS4, its just a 15" short horn (like BS600 but slightly smaller) with a compact but efficient midtop section, above bass/sub horns. Or is it because the USB2 is designed as a one box bass solution? |
Subliminal
Posted: 27 February 2012 at 8:29pm |
Thats the plan when we have the money. We had the MX350s before we even considered buying USB2s so the BS500s are there to fill the gap in the meantime. We're currently running the USBs 40 - 90hz, BS500s 90 - 200hz and MX350s 200 - 18khz. I'm trying to find some land in the middle of no where to get it set up properly with SMAART. |
tomschute
Joined: 15 May 2006 Location: Mid Wales Status: Offline Points: 1817 |
Posted: 28 February 2012 at 4:39pm |
The man's right. the USB2 was optimized to work in a 2 cab configuration. No need for kicks!
Also you should high pass the USB2 at 30Hz in x4. They will play upto 140Hz easy. You will need the correct filter settings to get them sounding sweet as they have a rising response above 90 Hz. Tom |
www.stableaudio.co.uk Speaker Building Services |
Subliminal
Posted: 28 February 2012 at 7:11pm |
When we have the funds we will be getting 4 more USB2s and some mid tops that will comfortably meet them. I know the USB2 doesn't need a kick bin, but unfortunately they dont play up to 200hz to meet the 10" in the MX350s so the BS500s are there to play the frequencies between. I think if we high passed them at 30hz in that tiny room the windows would have broken . |
Tom Tapey
Posted: 28 February 2012 at 7:32pm |
They were designed on the principal of a one box bass solution so yea i would move towards this if there is room for improvements. I would also recommend running the usb 2's as low as possible to avoid any of the horn honking that is so common it this type of design... so yea around 150hz max if needed. Sounds like you guys are going to have a load of fun with these, just make sure you use the correct RCF drivers if you get any more as this is key to this horn. Must catch up in the summer for some big link up action ![]() |
Subliminal
Posted: 28 February 2012 at 8:05pm |
We're well up for that. Just let me know where and when . |
oldskool_89
Joined: 27 November 2007 Location: United Kingdom Status: Offline Points: 438 |
Posted: 08 March 2012 at 12:46pm |
we have 2 more usbs if ur interested ;) £900 loaded
IMMUNITY SOUNDSYSTEM - [ImmuneFromTheSystem]
inter-sound
Posted: 08 March 2012 at 1:24pm |
Off topic but what venue is this ther is a fireplace lol? And i bet those 350s are the dogs, id get more and work ur bass and kick around them ;)
Tom Tapey
Posted: 08 March 2012 at 6:29pm |
USB 1'S ???
AUDIO HABIT
Joined: 15 June 2009 Location: Manchester Status: Offline Points: 3383 |
Posted: 08 March 2012 at 6:32pm |
i believe they are original ones yes
Page 123> |
