where to start with dmx |
Page 123> |
nuclearbass
Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
Topic: where to start with dmxPosted: 13 January 2013 at 3:40pm |
Hi guys ive finally got my system to a place im happy with, now on to the lights.
i have the following at my disposal, and have all the files for limelight verse and the dongle etc, 4x acme dyna scans 2x acme mighty spot moving heads 4x stairville led battons 1x kam fscan 40 laser 2 x abstract galactic moons so where do i start in knowing the dipswitch and LED display address settings to get me started, a push in the right direction for some usefull info and guidance is what im after, cheers in advance rich )
one life - have fun!
Force fusion pro audio |
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8800 |
Posted: 13 January 2013 at 5:21pm |
In the software you will 'patch' each fixture with a start DMX address.
So, if you a scanner with 4 channels and you patched it at address 10, it would occupy channels 10,11,12,13. You then set the scanner to channel 10. You need to make sure that no channels overlap, most software will warn you about this. Personally, if I have the channels free I like to patch groups of fixtures starting nn1. E.g I might patch scans starting at 101, strobes at 201, pars at 301,etc. And sometimes I might do each fixture as well, so the scans might be 101,111,121,131,141,etc. it is wasteful of channels, but can make it easier to remember the required address when settings heads after doing the desk patch, especially if the desk is at front of house and you've no-one to call them for you |
Amplighting&sound
Joined: 31 July 2011 Location: Essex Status: Offline Points: 359 |
Posted: 13 January 2013 at 5:22pm |
Hello first down load a dmx calculater app its wicked then find all your light manuls as they will tell u what dip switchs do what and u might find s ome of your lights maybe crossed dmx so u will need to find this out first if u wanted to link all lights on one line
nuclearbass
Posted: 13 January 2013 at 5:30pm |
ok i think i understand, i know that each light will have x amount of channels for light gobos etc etc
so to controll each scanner independantly it would be scanner 1 = channels 1234 || scanner 2=4567 and so on?? right ok, the led bars have 3 segamnts which ive been told work in slave master mode, so does this mean to run each segment seperate id have to do the same, segment 1=10 11 12 13 segment 2=14 15 16 17.? im guessing the laser pretty straight forward., and same with the galactics..... how do i find out if my lights are crossed dmx?
norty303
Posted: 13 January 2013 at 7:13pm |
I have no idea what he means by crossed DMX. He may mean that you could have channels overlapping, but that is purely a function of you patching badly rather than any issue with the fixture.
The LED bars slave mode is irelevant when used on DMX. you should be able address each segment as if it is a single RGB fixture. The same profile for a 3 ch LED par should work for each segment, assuming they don't have some other funky control channels. |
nuclearbass
Posted: 13 January 2013 at 7:21pm |
ok i see what you mean norty, im guessing it will be a little easier whne i have the softwere in front of me, i just need to find the manuals for the lights now, or will the nice people at limelight already know how many channels each one of my fixtures needs?
dylan-penguinmedia
Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4542 |
Posted: 13 January 2013 at 8:54pm |
Crossed DMX may mean some lights have the pins swapped - like some older amps might on the audio side. Some older Martin Lights are this way inclined. You can make up leads or get polarity swappers from CPC for a quid or two.
norty303
Posted: 13 January 2013 at 9:01pm |
Ah yes, I see it now!
![]() What lights in use today have reversed polarity DMX other than the 218,812,518 Martin Roboscan series? |
dylan-penguinmedia
Posted: 13 January 2013 at 9:06pm |
Who knows.... I've a Martin Imagescan that is... But seeing as its spent the last year or so on my bench, I don't class that as 'in use today' haha! |
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 13 January 2013 at 9:48pm |
Abstract use reversed polarity DMX, at least vrx's do - worth checking the galactic moons...
nuclearbass
Posted: 13 January 2013 at 9:59pm |
cheers for that mate, probably save med some head scratching |
nuclearbass
Posted: 13 January 2013 at 10:09pm |
heres the galactic moon
(pin 3 cold, pin 2 hot, pin 1 grounded) is that normal? or reversed?
Page 123> |
