Mackie Thump 15A Amp problem |
Page 12> |
teknojay
Joined: 08 November 2006 Location: Peterborough Status: Offline Points: 415 |
Topic: Mackie Thump 15A Amp problemPosted: 30 January 2013 at 9:44am |
Hi all
I have a mackie thump 15A that is in need of repair. It plays fine at really low volume but as soon as it hits a certain volume it starts popping, making strange noises and keeps cutting out then back on. Any ideas as to whats wrong with it? I think it may have blown something in the amp or the protection circuit as the drivers sound fine when their working. Anyone on here repair active speakers? local to Peterborough preferably but dont mind couriering elsewhere. Proper annoyed me as its warranty ran out last month lol always the way :( Cheers Jay |
mk2_ginger_biscuit69
Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7797 |
Posted: 30 January 2013 at 3:11pm |
did you need to post this twice?
random stab in the dark, but it could be the capacitor bank has died, so is clipping early making said popping noises, or even simpler, you could be clipping the input through either having the input on mic instead of line level, or simply sending far too hot a signal from source and having the speaker level low - albeit unlikely if it is a recently developed fault and it hasn't been an issue in the past on the same setup? |
teknojay
Posted: 30 January 2013 at 4:02pm |
Hi mate sorry for double post i just didnt know what section would cover active speakers. Not been clipping the input or anything like that, have 2 of them that run from the same source(booth out on djm) one L one R and the other ones fine ![]() |
JR.junior
Joined: 14 December 2009 Location: Slovenija Status: Offline Points: 1789 |
Posted: 30 January 2013 at 4:50pm |
Could be the zobel rc network, capacitor leakage. Most likley on the HF output.
funkyparrot
Joined: 12 December 2010 Location: Leicestershire Status: Offline Points: 841 |
Posted: 30 January 2013 at 5:39pm |
Have you checked speaker links from the amp? If found O.K.tried feeding the driver from a different amp, still not found? Then internal amp feeding another driver.
That's what I would do, eliminate links in the chain to isolate faulty component.
Posted: 30 January 2013 at 5:43pm |
*ignore*
Edited by mk2_ginger_biscuit69 - 30 January 2013 at 5:44pm |
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 30 January 2013 at 9:42pm |
This is good advice but beware that active cabs will often use low impedance drivers in order to get the most from the matched amp (I've no idea if this is the case with your 'thump') so substituting in an 8 ohm driver (for example) will not necessarily give an equateable volume. Also take care as there will be dangerous voltages around once you open it up. It sounds like it could just be a seized / damaged driver to me . Try gently and evenly pushing the cone in and out, it should move freely without rubbing scraping noises... |
teknojay
Posted: 30 January 2013 at 11:07pm |
I don't like toying with things like this so am sending it off to AbleTronics for repair
thanks for the help though guys :) |
Conanski
Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2757 |
Posted: 18 February 2013 at 3:51am |
You have a blown driver which is not at all uncommon with these boxes unfortunately.
Edited by Conanski - 18 February 2013 at 3:52am |
In Hope
Joined: 16 June 2013 Location: oxford uk Status: Offline Points: 1 |
Posted: 16 June 2013 at 3:25pm |
hello, just come across this looking for something else.
i just bought a thump 15a cheap as a writeoff, for interest really. having spent a lot of time with it, i can add some experience. i can say that all of the above suggestions are reasonable but given what i have seen, the cause is probably mechanical failure in the circuits or wiring. the spade connectors to the drivers are barely hanging on and will become intermittent as the power rises. the pcb/component soldering is shocking, so expect dry joints. the unit i have mostly repaired had a tricky fault in that a solder pad of a xformer leg was not actually connected to the pcb track leading from it. i have resoldered all joints possible now. you might consider converting it to passive and throw the electronics away if that is where the fault is. as suggested above, you can separate the amp from the speakers to check each independently. repeat warning of exposed high voltages inside. |
AvLee
Posted: 16 June 2013 at 3:30pm |
I've got one doing the exact same thing that I've just dropped off to Service Steve!
service dept Steve
Joined: 30 January 2010 Location: S.W.London Status: Offline Points: 2050 |
Posted: 16 June 2013 at 11:50pm |
Short circuited LF driver, It shows as 1 ohm and so the amp pulses as it protects itself from the over current. The bass driver is a "close to the bottom of the range" eminence.
Page 12> |
