Dual 18 HBPH |
suiluj
Joined: 28 November 2007 Location: Phil/Singapore Status: Offline Points: 202 |
Topic: Dual 18 HBPHPosted: 30 September 2016 at 5:37pm |
Hello guys,
What would be other softwares to possibly simulate this hybridbandpasshorn? Still working on AJhorn but still can't get it right. Cheers! ![]() ![]() |
BooM BASSTIK EleCtronics and Communications Engineer
Live in harmony with one another. Do not be proud, but be willing to associate with people of low position. Do not be conceited. |
fatfreddiescat
Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1128 |
Posted: 30 September 2016 at 5:53pm |
AKABAK
suiluj
Posted: 30 September 2016 at 6:00pm |
Cheers,
I will work on it especially on the 32bit emulator, I am currently running on a 64bit windows. |
fatfreddiescat
Posted: 30 September 2016 at 6:24pm |
Look forward to seeing the results of the stubs.
suiluj
Posted: 01 October 2016 at 2:06am |
Will post new updates after finishing the prototype, start cutting woods next week. ![]() ![]() Edited by suiluj - 01 October 2016 at 2:35am |
fatfreddiescat
Posted: 01 October 2016 at 10:24am |
For the stubs I would think in terms of mass and compliance as regards to the chamber and ports, there will be a resistance component, more so if the ports are made up of lots of small holes instead of three or four larger holes.'Hornresponse' by David McBean would model all but the stub, much simpler to use for initial design and the output can be imported into AKABAK.
bitSmasher
Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2302 |
Posted: 01 October 2016 at 1:29pm |
Could you use the stuffing/damping function in Hornresp to emulate the resonator?
Might be worth starting a thread in DIYAudio sub forum, some seriously good sim geeks on there (including McBean) |
suiluj
Posted: 01 October 2016 at 2:51pm |
![]() ![]() Thanks guys... been spending few hours on this AJhorn at the moment.I will try to look further on the hornresp. Also I have check the DIY audio sub forum, guess you are right bitSmasher, a lot of geeks there with good discussions to ponder and learn including stub/cone compensation. |
