  New Posts New Posts RSS Feed - PKN H8
PKN H8
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2017 at 10:35pm
PKN H8 is coming soon! Worldwide best switching amplifier technology with 1MS/s+ sample rate, exceptional signal accuracy & pulse response in fully
symmetrical configuration at very high power levels by PKN Audio. Stay tuned for updates.
Basic features of PKN H8 technology:
- First affordable multilevel high-power professional audio amplifier brings the advantages of multilevel inverter technology into the proaudio fileld
- Improved reliability due lower, distributed losses over 8 power processing elements instead of 2 (typical for common Class-D amplifiers)
- Exceptional signal accuracy due advanced multilevel & multiphase PKN H8 modulation, fixed frequency operation
- Effective sample rates over 1000KS/s directly from the analog signal input
- True output U/I feedback loop(s) for fully load independent frequency response
- Improved large signal bandwidth and pulse response, at least twice of useful frequency range compared to Class-D
- Power of 8 switching elements added therefore suitable for the upper power range, above 5000W/ch on 4Ω
- NO 'common rail' structure , overload on one channel does not immediately influence the others
- Very high power conversion efficiency, less than 1/4 of the losses compared to conventional Class-D
- Full reactive load and energy recycling capability, Class-D 'bus pumping effect' eliminated, good low frequency response down to DC
- Wider useful bandwidth allows larger loop-Gain of control therefore damping factor over 10000(@50Hz and bellow) becomes possible
- Advanced user programmable NoClip/U/I limiters for each individual channels
- Worldwide operational ability with matching Universal mains PFC power supply
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2017 at 12:36am
I'm just wondering will it handle scoops!!?
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2017 at 4:32pm
I'll believe it when I see one sold – unlike the mythical 3PHASE and XE10000…
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 07 November 2017 at 8:55am
I wasn't allowed to buy PKN they told me to uck off.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2017 at 10:50am
U.Viktor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2017 at 1:09pm
Just informed my friends had a demo H8 months ago, sounds like class A but the headroom and power is on steroids!
Still I can not figure out how would it be "affordable or economical" while has four times the components inside?
The V8 engine is a good example, neither of them called cheap!  :-D
Edited by U.Viktor - 18 November 2017 at 6:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 19 November 2017 at 5:50am
It’ll be affordable because you won’t be able to buy it.
MPASOUND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MPASOUND Quote  Post ReplyReply Direct Link To This Post Posted: 20 November 2017 at 10:43am
I love how excited people get with new stuff! I'm sure it's very good but when was the last time anyone heard a PA system on a Class A amp to make that kind of comparison?
It's just bits of paper flapping about in a box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 20 November 2017 at 7:50pm
I did. Today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2018 at 6:46pm
I saw and hear it. Not much different look than xe10000 from outside.
10KHZ triangle wave is still triangle at 2 Ohms and 10KW/ch.
goes down to DC. [0Hz..] ..  :-D
the 100A one phase mains connector bit strange
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2018 at 7:04pm
PKN H8-18002U (2x 5500W @4Ω | 2x 9200W @2Ω)
I wonder if there are further models and any DSP?
Franz Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Franz Francis Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2018 at 7:53pm
Is it stable into a full time two ohm load for several hours or for the duration of the gig?
Franz
